I don't trust my table saw (old POS, inaccurate. I need a new one), so I cut mine on my band saw. I take a measurement at the nut for width, establish a centerline, and go out from the centerline on each side one-half the total width. I do the same on the 21st fret. I use a straight edge to mark a line at the marks I made off the centerline, and pencil in a line. I then take it to the band saw and cut, leaving about 1/16" outside the line for truing up, once I get the fret board on.
Sorta like this.
True up with a block plane and, at the transition to the headstock, a spokeshave. Or a sander.
I don't.
I make them 1" at the first and 1" at the 12th...
I thought the OP was talking about the sides... If it's the thickness, I just use rasps, spokeshaves, and block planes.
Radius the fretboard with a block
Getting ready to make a few necks and was wanting to do a compound radius, Colt, do you do constant radius only, or do you have a slick way to do the compound radius?
(You seem to have a slick and wonderful way to do most of this. Thank for sharing your knowledge!)
Guy
I wish I could take credit for this, but this is slicker than pig $#!+
http://www.tdpri.com/forum/tele-home-depot/228113-fingerboard-radius-jig.html
I took the OP to mean 'how do you thin the back of the neck'.
Sure, some gorilla-pawed goons like Simpson leave the neck the same thickness all the way up but others of us lesser-endowed in the 'handal' regions like to bring it down some to .850" or so.
As far as getting the neck to the same width as the fingerboard, after the glue is dry I rough it out with the bandsaw and use a 1/2" pattern bit on the router table to clean it up. No fuss, no muss and takes 5 minutes.
