Let’s talk potentiometers
Discussion in 'Bad Dog Cafe' started by Mission6_OG, Jul 30, 2021.
  1. Mission6_OG
    Mission6_OG Tele-Meister
    Louisiana
    How much impact does pots have on tone? Playability, etc.? I just received my Bullet Tele and have ordered licking tuners and saddle with 3-piece brass saddles. I really got this guitar to learn how to replace parts on my own, learn more of the inner workings of my guitar, etc. but seriously, how much improvement, and what is that improvement on the guitar itself with upgrading my pots?
    Boreas likes this.
  2. Fretting out
    Fretting out Doctor of Teleocity
    Land of Mary
    Pots don’t care how much they cost as long as they are the right value, especially if you play wide open
    Of course some have better sweep and feel than others
    Depends on how much you use them and how you use them
    If you’re a constant knob fiddler I would get some high quality pots
    Ebidis, OlDefGuy, Boreas and 3 others like this.
  3. 68tele
    68tele Friend of Leo's
    East Northport NY
    Licking tuners? Seems sketchy
  4. bumnote
    bumnote Tele-Holic Ad Free Member
    Northern Virginia
    If they work well and are decent quality...not much. Unless you want to go from 250k to 500k, personally I don't like single coil pups with 500k pots...too shrill for me.
    Changing the cap will make a difference. .047 is standard for Fender, personally I prefer .033...less 'muted' & muddy when dialed to 0. I'd explain it like this, dial from 10 down to 4 with a .047 cap...you get that range across 10 to 0 with .033. Little more room to fine tune.
    OlDefGuy likes this.
  5. Killing Floor
    Killing Floor Friend of Leo's
    Austin, TX
    Thought this was a Jimi Hendrix thread.
  6. popthree
    popthree Poster Extraordinaire
    a hawk makin lazy circles
    you could remove them entirely, then you'd have someplace to hide your weed
  7. Toto'sDad
    Toto'sDad Tele Axpert Ad Free Member
    Bakersfield
    If you encounter someone in your audience doing this, you may have a tad too much treble dialed in. (Quite common with Teles)
    JRapp, Chipss36 and Obsessed like this.
  8. northernguitar
    northernguitar Friend of Leo's
    North of Toronto
    Pot does have effect on my tone.
  9. Fretting out
    Land of Mary
    I KNEW IT! I knew one of you dang hippies was gonna stop by...
    Dang it @popthree ! Too, I’m surrounded!
    I can smell your patchouli oil from here
  10. posttoastie
    posttoastie Friend of Leo's
    orange county,ca
    I remember that the more you paid the better it usually was. So yes pay more for quality pots.
    WalthamMoosical likes this.
  11. northernguitar
    North of Toronto
    Hippie? :twisted:
    More like this….
    Fretting out likes this.
  12. schmee
    My experience is some pots are good and some are not. Even some of those small bodied pots are excellent. But sure, there are bad ones too. Not sure you can draw that "quality priced" pots are better though.
    Case in point: Years ago I bought a used DRRI cheap. It was a closet classic and appeared brand new. I had a vintage AB165 eyelet board so I converted the amp to a vintage style hand wired amp.
    At the time everyone was saying "drill out the faceplate holes so you can put in full size pots".
    In the end I decided not to. Those mini pots used direct on the circuit boards were super smooth and nice. SO I took them off the board and wired right to the tabs on those pots. I was very happy with the result.
    I have a bunch of old Japanese guitar pots laying around. Some of those mini's are very smooth and noise free also.
    CTS pots often are not very uniform in "turning resistance" at all actually. Still, I mostly use CTS pots....
  13. posttoastie
    orange county,ca
    In the 90s Fender had the Smugglers, I mean Swimming pool route for Strat bodies. That must have been so you could store Pots in there.
  14. loopfinding
    loopfinding Friend of Leo's
    europe endless
    the ones designed for "guitar use" have a nicer/more usable taper than others. but some alpha 24mms are not any worse or better quality wise. and tone is a non issue. same with caps.
    a lot of "upgrades" are just personal preference and not a quality thing. even cheap pickups are just a preference thing (and lord knows i love those ceramic MIM pickups from the 90s more than some "period correct" emaciated alnico thing).
    the best "upgrade" you can do to a cheap guitar is taking it to a good luthier and paying for stellar fretwork & setup. it's not food, the quality of the "ingredients" is mostly the same after you pay a smidge more than market rate for any one component. the money you pay for premium guitars is in the labor and care taken in the luthiery work.
  15. Fendereedo
    Fendereedo Poster Extraordinaire
    Sunny Suffolk UK
    Don't get your tongue caught. ;)
    RobRiggs and Mission6_OG like this.
  16. Mission6_OG
    Louisiana
    Yeah...it was a rough night. Lots of drinking. Cut the hell out of my tongue trying to tune my b string. It was bad.
    Fendereedo likes this.
  17. Boreas
    Boreas Poster Extraordinaire
    Adirondack Coast, NY
    Pots matter quite a lot. Choose the wrong value, taper, torque, etc., and you will know instantly what pots do and don't do. The weakest part of Squier electronics is usually the switch. If you like the taper, tone, and torque of the stock pots, you are all set.
    HOWEVER, you said you wanted a learning experience. What I would do in that case is actually build your own control plate with different pots, caps, and a better switch. Then swap the plates and whammo - you have new electronics and a guitar that sounds different. Use the new plate to experiment with different values and tapers and such, and it will be fun. But I would hold on to the stock plate for originality. Those Bullet Teles may be worth thousands some day!!:D
  18. Fendereedo
    Sunny Suffolk UK
    :D
  19. Mission6_OG
    Louisiana
    That answers that question. I really don’t mess with the knobs on my guitar much at all really. I guess because it’s all still do much of a learning curve and I’m still really finding “my” sound.
    Boreas likes this.
  20. Dostradamas
    Dostradamas Tele-Meister
    Oregon
    Confucius say
    "Man who stand on toilet, high on pot"
    I use the cheap ones till they get noisy then put in CTS solid shafts
    Tone tis in the digits yo
