Les Pickup-Ectomy
Discussion in 'Just Pickups' started by fatcat, Aug 24, 2019.
  1. fatcat
    fatcat Friend of Leo's
    Very Deep South
    It's Time IMG_20190818_140435311.jpg IMG_20190818_141639778_HDR.jpg IMG_20190818_141702984.jpg
    I've finally done it.
    rze99 and idjster like this.
  2. fatcat
    Very Deep South
    Bagged components so that process is reversible.
  3. fatcat
    Very Deep South
    Prepare Template
    Selection of pots; values checked
    Selection made; pots loaded:
    Neck tone: 520k
    Neck volume: 508k
    Bridge tone: 516k
    Bridge volume: 503k
  4. fatcat
    Very Deep South
    Caps Installed
    Bridge: 0.022
    Neck: 0.015
    Ground lugs folded and soldered
    Time for wires
    joebloggs13 and RodeoTex like this.
  5. deus56
    deus56 TDPRI Member
    Very cool, hope we get a tone report.
  6. fatcat
    Very Deep South
    Clarification:
    This is a 50's style circuit layout..
    But you guys may have been able to tell that already.
  7. jimilee
    jimilee Tele-Afflicted Silver Supporter
    Chattanooga
    I’m itching to do that to all of mine.
  8. RodeoTex
    RodeoTex Doctor of Teleocity
    Nueces Strip
    After doing a couple of Les Pauls I spent a few minutes and built this little soldering jig from scraps.
    It's proven to be well worth the time.
    fatcat, CFFF, studio1087 and 2 others like this.
  9. jvin248
    jvin248 Poster Extraordinaire
    Lions & Tigers oh Mi !
    +1 keeping the parts in a bag to save and getting all fresh parts.
  10. Chief101
    Chief101 Tele-Meister
    Not far from Nashville
    Few things more attractive on a guitar than a control cavity with well-wired controls. Plus, I’m not a fan of a PCB in an LP control cavity. Looks ...... wrong. Good stuff all the way around.
    cottonmike likes this.
  11. Jim603
    Jim603 Tele-Meister
    New Hampshire
    I would do the same thing. Even if it makes no difference in the sound, (which I'm sure it will,) I'd still consider it an improvement. I'm old-school that way.
    fatcat likes this.
  12. fatcat
    Very Deep South
    Thanks gang..
    Using an awl to fray the shield and get to the signal wire.
    This will the bridge pickup connection to the switch, and establish the ground bond between the pot casings.
  13. fatcat
    Very Deep South
    Connecting to the pot; you can see that the holes aroud the perimeter of the template board were deliberate to help keep the excess conductor under control.
    And the complete loop with heat shrink installed per my OCD.
  14. fatcat
    Very Deep South
    Subject change.. I want to admit that I can be a clumsy idiot.
    Check out the scar I made in the top a couple years ago when the screwdriver slipped as I was lowering the tailpiece.
    Worst possible spot.. if I ever did try to sell this guitar..
  15. jimilee
    Chattanooga
    Been there done that...twice.
    fatcat likes this.
  16. Antigua Tele
    Antigua Tele Friend of Leo's
    west coast
    I'm guessing the push pull pots split the HB's, I wouldn't have wanted to lose that option, personally. It's hard to believe Gibson touts itself as a premium brand while also making use of PCB where none existed before, but then again I guess that's why Henry J spends his days golfing now.
  17. t-ray
    t-ray Tele-Afflicted Gold Supporter
    Vermont
    I just can't get over the fact that Gibson did that to their premier guitar, putting those boards in there. Mr. Paul was probably spinning in his grave. I learned about this very recently when I bought my 2019 LP Jr., which is very nicely hand wired.
  18. Antigua Tele
    west coast
    The model Les Paul preferred was the "Recording" model, which was more technologically ahead than the the standard model, as it had a hi/lo Z output selector and a phase switch, so he might have been OK with the PCB thing. I don't think he ever had much love for the standard Les Paul model, and putting his name on it was a marketing thing.
    rangercaster likes this.
  19. fatcat
    Very Deep South
    IMG_20190824_144240037.jpg Dry fit...
  20. fatcat
    Very Deep South
    Got caught up and forgot to take pictures.
    Here's the switch with the output and the switch to neck volume pickup conductor. IMG_20190824_160335299.jpg IMG_20190824_160341453.jpg IMG_20190824_160317367.jpg
    RodeoTex likes this.
