Lefty Compensated saddles
Discussion in 'Tele-Technical' started by fozhebert, Jan 24, 2018.
  1. fozhebert
    fozhebert TDPRI Member
    Charlottetown
  2. gsh1968
    gsh1968 Tele-Holic
    London UK
    If they are genuine Fender saddles then no, because they have a flattened underside.
  3. BryMelvin
    BryMelvin Tele-Afflicted
    Arivaca AZ
    But you CAN buy two sets, Then use two middle ones and one outside one. If you use a wound G you would use 3 sets and then 3 middle ones
  4. boris bubbanov
    New Orleans, LA + in the
    Foz, check out the Stew Mac website and look at the # 5167.
    Those can be flipped. Some folks want to "compensate" only one of the 3 stock saddles and they have with the # 5167, enough for 3 guitars. It can be flipped because it is uniform in section - either side can serve as the top.
    But first, ask yourself how high your saddles are set up, to play as you want them to. Some folks have their outboard saddles "slammed" enough that there must be some relief on the underside of those # 5167 saddles. You could get those 3 saddles all set up "Lefty Style" then determine how much, if any, brass you have to file off the undersides of those outboard saddle ends to get your E strings down where they need to be.
  5. fozhebert
    Charlottetown
    Thanks for the information guys. I may go another route. Since I'm not a big bender, I may just get a straight set of saddles and use a wound 3rd. I believe d'Addario makes a set w/ wound G 0.018, I may try that. I've read the wound 3rd really helps intonation. I've bookmarked JD's instruction on setting intonation and will give that a try.
  6. LutherBurger
    LutherBurger Friend of Leo's
    NYC
