Leaving out artificial center tap
Discussion in 'Amp Tech Center' started by Diverted, May 23, 2020.
  1. Diverted
    Diverted Tele-Meister
    Bristol RI
    I just built a small Champ 5f2a, finished it up and started playing it. The amp is very quiet with no hum.
    Last night it dawned on me that I did not put an artificial center tap on the heaters.
    Is there any other safety/stability reason to put them in, other than hum control? Because this amp really doesn’t hum! I may leave as is unless I need the artificial tap.
    Also: the 6.3 winding does not have its own designated center tap.
  2. robrob
    United States
    The artificial center tap is for hum control so with no hum you're fine.
    King Fan likes this.
  3. tubegeek
    tubegeek Tele-Afflicted
    Brooklyn, NY
    You may not get the same results with every choice of tubes.
    King Fan and robrob like this.
  4. trobbins
    trobbins TDPRI Member
    Melbourne
    The heater has a high resistance to each cathode. Two cathodes are bypassed so their DC voltage won't change much. If you didn't tie one heater side to ground (as per original) then although the heater is floating, it will effectively sit at a few positive volts dc (along with the ACV from the heater winding), so won't cause any stress on the heater-cathode voltage limit.
