Learn something new everyday.
Discussion in 'The DIY Tool Shed' started by Tdel10, Nov 27, 2016.
  1. Tdel10
    Tdel10 Tele-Meister
    Wheeling WV
    After I broke three of these things, brass furniture insert nuts sized 10/24, I got the idea to go look and see if anyone made them out of stainless or something harder than this cheap, soft brass. They do online, but Lowe's only carries the brass ones. I was being super gentle, had the correct size hole drilled, using the best fitting flat head screw driver possible and SNAP! Three out of four neck bolt inserts broken below the surface of the wood. Great. That's just what I wanted to happen. 20161127_005056.jpg
    I was a bit ticked off honestly and thought "there's no way that should happen that easily, how does ANYONE use these things?!"
    Off to YouTube I go and low and behold, user error on my part. First time that ever happened :rolleyes:
    Now, because of this video I realized my blunder and use this, threaded in "backwards"... Which isn't backwards at all... instead to install these little buggers. Man, what a difference it makes when you actually use something like it was designed to work. 20161127_022415.jpg
    Enno likes this.
  2. Jupiter
    Jupiter Telefied Ad Free Member
    Osaka, Japan
    That's a neat trick. I'll be filing that away...
    Tdel10 likes this.
  3. guitarbuilder
  4. Reckless Rat
    Reckless Rat Tele-Meister
    Thanks for sharing. I absolutely would have assumed that they were intended to be driven by a big flathead screwdriver!
    I keep meaning to look for a source of these inserts. Now if I ever buy some there's a chance I might use them properly!
    Tdel10 likes this.
  5. Dan Miller
    Dan Miller Tele-Meister
    Thousand Islands, New York
    mcmaster.com is a great place to get threaded inserts (stainless steel, nickel-plated steel and brass). They also have installation driver bits.
    If your workpiece fits on the drill press, cut the head off your bolt and chuck it in the DP. Turn the chuck by hand (Don't turn the DP on!) and it will drive the insert in straight.
    RogerC, milocj and Tdel10 like this.
  6. milocj
    Michigan
    I use the McMaster-Carr steel ones. They have a standard thread on the outside which allows you to actually tap the hole before installation.
    Tdel10 likes this.
  7. Vizcaster
    Glen Head, NY
    Inserts are also available that have a hex recess so you drive them with an allen wrench (or a driver bit for that size allen key). For the brass ones that fool you into thinking they can be driven by a screwdriver, it turns out if the flat-bladed screwdriver is big enough to fit the tip, then it won't fit in the hole; I use the driver insertion tool from Rockler or Woodcraft in a small cordless impact driver - seems like a waste of money but it works perfectly and doesn't bind - real time saver.
    Tdel10 likes this.
  8. Tdel10
    Tdel10 Tele-Meister
    Wheeling WV
    I could see that being necessary in some of the super hard woods. Good to know!
  9. Vizcaster
    Glen Head, NY
    The solution for hard woods is to use a drill that's at least a 64th bigger; most suppliers have charts for their inserts.
