Matthias
So here's my latest parts build, a sort of early Christmas present to myself. And it sparkles enough to hang on a tree. This was built to alleviate several different types of GAS. We'll see how that lasts...
The body is one of the sparkle HB/SC thinline bodies that you can buy from several sellers on eBay at the moment. I suspect it's the same factory cranking these out. The finish is great with the only flaw being three tiny specs of glitter on the binding. The F hole edging was a little messy, so I painted the edge flat black. The fit for Fender parts is also very good, and the only work I had to do was sand some finish out of the ferrule holes.
The neck is a Fender American Performer neck. I used an American special neck on a Strat build and for the quality/price ratio (if you can get them below RRP) they are very good. I love the satin finish and the fret work/nut are pretty much ready to go on these. I could do to file the top of the nut down a little but it’s not causing any serious binding at the minute. Tuners are staggered American pro tuners. I’m getting better at putting the US-style string trees on but it's still my least favourite job... It's straight enough to make it out of the factory, put it that way.
The bridge plate is the cheaper-end Fender vintage job. The saddles are Gotoh In-Tunes, which function well and have a classic look to them.
Pickups are Lollars - J-Street (8.7k) in the bridge and a standard wind Imperial (7.6k) in the neck. Both sound great and very vintage, as you'd expect. The wiring puts a 470k resistor in parallel with the bridge pickup, so the 500k volume pot is seen as about 240k on middle/bridge positions. Usual CTS/CRL/cloth wire insides along with one of the cheaper-end NOS Eastern European 0.0022uf capacitors for looks (I will post a pic later). Finally, it has an electrosocket-style jack cup.
I'm very happy with how this one went together. Everything fit well. No mistakes or accidents. Electronics worked first time. Plays great with about as low action as you'd get without a fret level. Just about 7lb.
