Late 70's Fender SF - Pull boost feature
Discussion in 'Amp Tech Center' started by Stax1, Mar 29, 2020.
  1. Stax1
    Stax1 Tele-Meister
    Over here
    Hi guys, thought I'd post this question up for the learned bunch that may have some technical knowledge of the late 70's Fender SF amps that have the super fancy 'pull boost' master volume.
    I have a late 70's Pro Reverb that has this and while I can see why lots of folks dont like it, I can find some pretty unique tones out of it. To me it sounds a lot like its trying to create a mid frequency boost, for cutting solos through a mix etc..
    Anyway, can anyone who has some technical understanding explain what the feature is doing in lay terms?
    Following - could this feature be modded to be more useful to more folks? ie, mod it to boost all frequencies? or be a treble boost?
    Also - what would removing it from the circuit do? Nothing..?
    Maybe the pull feature could be modded to remove the tone stack?
  2. lil scotty
    lil scotty Tele-Meister
    Phoenix, AZ
    You will get some good answers shortly, I'm sure. I do believe that removing it from the circuit will do nothing. My understanding is that when knob is not pulled, it's just like it's non push/pull counterparts.
    Stax1 likes this.
  3. Dacious
    Dacious Poster Extraordinaire
    Godzone
    The pull boost diverts the reverb drive signal and mixes it back into the dry as increased gain. One problem is the driven tone off the 12AT7 is put through a small value cap to stop bass flub. The distorted signal is a bit bright and thin and fizzy. The other problem is there's no way of altering the mix level independent of volume.
    Pulling the circuit might give a bit more channel gain in theory. It might do nothing. You could use the switch and jack for something else like a midboost.
    Fretting out likes this.
  4. Stax1
    Stax1 Tele-Meister
    Over here
    Ah, that would explain why it sounds a bit 'nasal' at some settings. it also explains (I think) why it lessens the amount of reverb in the tone - eg, pull the boost and the sound becomes a little louder overall, but the amount of reverb in the mix is the same is it was before pulling the switch, which has the effect of sounding like there's less.
    So if we were to change the value of that cap that it goes through (or remove it), would that make it sound fuller?
  5. Dacious
    Godzone
    I had three amps with this feature - 70 watt Pro, 40 watt Vibrolux Reverb and Princeton Reverb, and it sounded like doodoo with all.
    It actually cuts reverb off, what you're hearing is the clean from the the vibrato channel injected with the same signal through tube gain stages. There's no mix or depth control to it. It's like early attempts by makers to add drive. Just not right sounds and not adjustable enough.
  6. Stax1
    Stax1 Tele-Meister
    Over here
    Yeah its not a drive that inspires a lot.. My amp is a 70w Pro as well. I've been wanting to get it into a rehearsal so I can test the pull boost at volume and see if it helps it cut through a band mix or if it just comes out sounding anemic...
    I can get good tones using it, but it means adjusting other things B/M/T and channel volume. Its just a bit weird..
  7. tubelectron
    tubelectron Tele-Afflicted
    France
    Yes - look at the tone-stack of the Boogie MKIIA below :
    It is a good volume-mid boost, and if you want to boost the treble also , remove the 5nF cap in // with the 22K. You can also increase or minor that 22K depending on the effect you want, as you can also play with the 5nF cap value...
    I have done this simple trick to several of my amps with success (SF DR, SF PR). I find it more usable on stage than the original "through reverb" boost circuit there was on these amps.
    -tbln
  8. Marcusin
    Marcusin TDPRI Member
    Biloxi Ms
  9. Marcusin
    Biloxi Ms
    Ive been doing this from when I was 17 the amp on the vid was my bandmates from the 80's im now 58 on my SF 's I put a active loop in using the tremolo circuit's 12Ax7 this plug uses the reverb circuit so the reverb knob is now overdrive, the old reverb tank if shaken sounds like a garbage truck to me, that's why I get rid of that tremolo circuit too in place of a good loop, I heard many experts, Tech's , guru's say bad things about The Pull Boost Master Volume Fender amp's But if you make that plug which if you dont like it pull it out you will find that your silver SF is a world class amp. now they need a closed back cab. vol 10 treb 4 mid 5 bass 3 reverb 10 master vol pulled and no more than 4 brite sw off plug in tremolo ch 1 make some real music THAT THE SF TRUTH ! 120k ohm 1/2 watt resistor ...
  10. Telecasterless
    Telecasterless Friend of Leo's
    los angeles
    Well, it is April 1st after all.
  11. Stax1
    Stax1 Tele-Meister
    Over here
    So was that just a late 70's amp with that reverb circuit jumped..? Sounded amazingly dirty for a Fender.. Then again, I've not really cranked mine up that much... Too f'n loud!
  12. SoK66
    SoK66 Tele-Afflicted
    Four Corners USA
    The pull boost thing can be safely ignored by not activating it, as noted. A couple things, the volume pots are linear, like a real mid-late 50s Bassman and most other large tweeds (the schematics are wrong), which means you're going to get a lot more volume, sooner. Also, going from memory, they continue something Fender started in '76 IIRC, lowering the cathode resistor value and eliminating the bypass cap on the reverb driver. This drives the gain higher on the tube. It stresses the reverb transformer and eventually they'll fail, giving a horrid, arcing and unmusical distortion on lower notes. When I've seen this on ones where I eliminate the pull boost I revert the reverb driver circuit to the earlier BF/SF spec.
