Laminating and gluing Padauk fingerboard
Discussion in 'Tele Home Depot' started by Dimitree, Aug 31, 2019.
  1. Dimitree
    Dimitree TDPRI Member
    Italy
    So I got a Padauk fingerboard blank from Stewmac, but is only 6mm thick. I think that after radiusing the blank (10”), the thickness on the sides could be too small, like 1mm or 2mm (not enough for side dots).
    So is it a bad idea if I glue two blanks togheter before radius the top layer?
    Also, what’s the best way to glue Padauk? Is it oily and so difficult to glue?
    Thanks and sorry for the noob questions
  2. RogerC
    RogerC Poster Extraordinaire
    Oklamerica
    Are you doing an extra wide neck? If not, your blank will be plenty thick enough for a 10" radius. There's no way you're going to remove 4-5mm from the edge of the actual fretboard.
    You can use regular Titebond on padauk.
    Treadplatedual likes this.
  3. guitarbuilder
    guitarbuilder Telefied Silver Supporter
    You can always put the dots on the glue line like many manufacturer's do. You probably won't have to though. Paduak will end up brownish after exposure to UV. My first ever guitar had paduak back and sides.
  4. otterhound
    otterhound Poster Extraordinaire
    Manheim Pa.
    If you are concerned about oil , wipe the Padauk down with acetone before gluing . Just be sure to allow the acetone to evaporate before adding glue .
