No change in signal path, just the switch position. If you are used to a 3-way, you slam it to 1 for the bridge or slam it to 3 for the neck. In the standard 4-way setup it is easy to hit position 4 (series) instead of 3 (neck). That can be an unwanted jolt. It is just personal preference in the position layout. Likely why some people go to push/pull pots to engage series, or throw in a neck HB instead.Really? What is different about the signal path in 3 vs 4?
