Labels? Small Stencils??
Discussion in 'Shock Brother's DIY Amps' started by Jewellworks, Aug 9, 2020.
  1. Jewellworks
    Jewellworks Tele-Meister
    Orlando
    im looking for labels or really small stencils to paint my chassis controls. i cant seem to find anything other than army lettering to paint your mailbox.
    looking for something small, cool, fancy...
  2. Rich_S
    Rich_S Poster Extraordinaire Gold Supporter
    Potsdam, NY
    "Real" amps are silk-screened, not stenciled. It's sort of the same, but silk-screening is a mass production process that requires up-front preparation and investment. It's not really practical for a one-off DIY amp.
    One DIY pedals, I have used clear plastic mailing labels, printed on my computer, then clear-coated. You have you be careful what kind of clear coat you use, so as not to melt the printer ink.
    bblumentritt likes this.
  3. dogmeat
    dogmeat Friend of Leo's
    Alaska
    decals is another way. you can buy sheets of decal paper & print your own
    I've built a few amps & made my own silk screens. its a lot of work but looks pretty kool
    heres my last one
    bblumentritt and Jewellworks like this.
  4. jtcnj
    jtcnj Tele-Holic
    N.J. USA
    Waterslide decals - I have a pack of the clear type but have yet to try it.
  5. BobSmith
    BobSmith Tele-Meister
    San Jose,CA
    Old school dry transfer like Letraset covered with a spray coating look great and are durable. They are just a bit hard to find, but are out there. It’s what I use for my custom chassis.
    I looked into silk screening and direct laser etching, but they are very hard to find and pricey (unless doing large volume). Custom latex letters are reasonably priced but now as good looking as the dry transfers.
  6. Jewellworks
    Orlando
    This is what I'm looking for. Is this the decals?
    "Decals". That is different than the water slide decals you can print? I tried a water slide decals, but it wasn't strong enough to be seen with the black chassis background. I tried printing yellow lettering (you can't print White) but came out as a very dark green once applied on the black chassis. Almost unreadable.
    I'm looking at custom "stickers" but they're expensive too...
  7. Alamo
    Alamo Doctor of Teleocity
    Berlin
    Not anywhere near silkscreen print but a lot better than some handwritten sharpie mess, I've seen.
    perhaps a Dymo Label PnP could suffice your needs
    edit: oh and the best thing about it, you can use any type font you have on your computer :cool:
    jtcnj and Gardo like this.
  8. dogmeat
    Alaska
    that was a silk screen. as for decals, maybe talk to a commercial print/graphics shop & tell them what you want. and yeah, a decal over black could be a problem. ask a pro. it's possible they have some scrap examples to try too
  9. Peegoo
    Peegoo Poster Extraordinaire
    Between the Raindrops
    Another option I've used in the past is to draw up a full-size layout (in color) of the controls and save it as a JPG. You can send this to any place that makes custom vinyl labels/decals; ask for the exterior-grade type--it's thicker and tougher. They can print you up an entire face plate for a pedal or amp. You stick it on and use an Xacto knife to cut out for the pots, switches, etc.
    jtcnj likes this.
  10. BobSmith
    San Jose,CA
    Can you post an example of how it turns out? Close ups would be great. Cheers!
  11. LudwigvonBirk
    LudwigvonBirk Tele-Holic
    Madison
    I concur BobSmith, and been there did that on quite a few guitar headstocks and some hi-fi stereo builds. My wife (print-magazine layout/design career) did the layout and alignment etc for me, looked real nice and sat under 5 coats of gloss with no ridges or bumps (which is a *thing* you have to deal with).
    For those maybe trying this (already said, it can work great): With Letraset you are effectively doing traditional (physical!) typesetting - “print-stock“ decisions, font choices, points, leading, kerning, contrast and composition, imprints, sheens, and all that- a very sophisticated and massively documented art form absolutely worth exploring (if you haven’t already done so).
    Final Letraset thought: buy at least 5 identical sheets so you can try various treatments and fix mistakes and tweak. If you don’t do that, you’ll probably have to significantly compromise on something you weren’t intending and ultimately regret.
  12. Steerforth
    Steerforth Friend of Leo's
    Arkansas
    Make a small silkscreen for doing chassis. It’s not hard, and there’s lots of books.
    When you’re not doing chassis, you can make crazy t-shirts and other stuff.
    tubegeek and LudwigvonBirk like this.
