L298TL noise issue not related to ground.
Discussion in 'Just Pickups' started by Voicing 13, Aug 28, 2012.
  1. Voicing 13
    Voicing 13 Tele-Meister
    Hey,
    I have a L298TL in spare par Esquire. I am using Bill Lawrences Special Esquire wiring.
    The noise sounds like static or a neon coming throught the signal. Here is what I have checked.
    My bridge is modern 6 saddle Gotoh and therefore bridge material should not be an issue.
    I have re-solder all ground connections.
    I have tripled check the diagram.
    I am a little at lost of where the problem could be coming from. Any insights would be appreciated.
    Thanks
  2. garrett
    garrett Tele-Afflicted
    Just south of Tampa Bay
    My first thought is that it's ground buzz. Does the noise go down when you touch the strings? If so, shield the electronics cavity.
