L-pad circuits?
Discussion in 'Shock Brother's DIY Amps' started by Mark the Moose, Apr 11, 2020.
  1. Mark the Moose
    Mark the Moose Tele-Holic
    Erie, CO
    Picked up an 8-om, 100 watt L-pad. Planning to house it in an aluminum enclosure with a bypass switch and a three-way treble switch like the elevenator. I won’t include an impedance switch since both of my amps are 8-ohm amps. Any other suggestions? upload_2020-4-11_13-40-43.png
  2. Uncle Daddy
    Uncle Daddy Tele-Afflicted
    Maldon, England
    Air vents. You don't want it to suffocate.
    Mark the Moose likes this.
  3. Guitarteach
    Heat sink
  4. Mark the Moose
    Erie, CO
    Think it needs it? 100 watt l-pad, aluminum enclosure, 35 watt amp, a few air vents on the sides...
  5. Bitsleftover
    Bitsleftover Tele-Meister
    Lincolnshire UK
    I built a 15watt version from this drawing.
    The bright cap values are way off.
    I went up in 2uf steps till I got to nearly 10uf before I could hear even the slightest difference even at extreme attenuation levels.
    I lost interest and didn’t push it any further.
    But if I were you, I wouldn’t waste your time with any setting less than 9uf.
    Having said that... I think it sounds pretty good. I just turn the treble up on my amp to compensate.
  6. Mark the Moose
    Erie, CO
    Wired it up with no tone caps and I don’t feel like it needs the treble bypass. Bright pups and a 6l6 Princeton reverb circuit has plenty of bright on tap, just bumped the highs a notch. Sounds great!
