Knob set screws
Discussion in 'Tele-Technical' started by saleake, May 1, 2021.
  1. saleake
    saleake Tele-Meister Silver Supporter
    At zero volume, where are the set screws on a new telecaster positioned; six o’clock?
  2. JRapp
    JRapp Tele-Holic
    Phoenix, AZ
    Well, I like to set them so the set screw is in line with the switch lever at full volume and tone. Easy to see where the volume and tone is set.
    basher, saleake and Bob Arbogast like this.
  3. Bob Arbogast
    Bob Arbogast Tele-Afflicted Silver Supporter
    Lowell, Michigan USA
    Yes. This gives a quick visual reference in the most important segment of the control's range.
    JRapp and saleake like this.
  4. saleake
    Set screws at full volume are at three o’clock. I like that. Thank you.
  5. JRapp
    JRapp Tele-Holic
    Phoenix, AZ
    Whatever works for you. I just got in the habit of doing that years ago and it just looks right to me.
  6. Frisco 57
    Frisco 57 Tele-Meister
    Arlington WA
    Set screw pointing straight forward (to the switch) at full volume so you can see 180 degrees of sweep.
    saleake likes this.
  7. Peegoo
    Peegoo Poster Extraordinaire
    Between the Raindrops
    If you're using knobs with set screws on split-shaft pots, make dang sure to place the knob on the pot shaft so the set screw locks into the slot, like this:
    Having the set screw lock against one of the split halves will bend it inward and break it.
    saleake likes this.
  8. Killing Floor
    Killing Floor Friend of Leo's
    Austin, TX
    Problem solved. You’re welcome. My pleasure is to assist.
    Do this:
    Ricky D. and saleake like this.
  9. Lonn
    Lonn Friend of Leo's
    Indiana
    I just installed 4 on my old Kramer. The problem with this thinking is that all set screws aren't pointed like your illustration. Mine all had a blunt end.
  10. Peegoo
    That's okay...a blunt end is fine too.
    You can use diagonal cutters to snip out a little rectangle of hard thin plastic, e.g., a 1mm guitar pick, and jam it into the slot. That allows you to place the set screw anywhere on the split shaft with no danger of crushing one of the halves.
  11. INFANT
    INFANT Tele-Holic
    Stoney Creek, Ontario, Canada
    I've got mine set up so that on full volume, they are facing me (we'll say 1:00 position). That way, i am able to see if I'm set up for soloing {1:00) or rhythm (11:00).
    saleake likes this.
  12. teleplayr
    teleplayr Tele-Afflicted
    Nicoma Park, Oklahoma
    I just use my ears.
