I used my new KoT pedal last night and I'm very impressed with it. It is advertised as being able to make a clean amp sound like a dirty amp at reasonable volume levels, and it sorta does that, kinda. I'm not real impressed with that aspect of the pedal though.
Where this pedal really seems to shine is in the area of a clean boost and adding a little hair to amp that is already on the verge of breaking up. In this application the KoT pedal adds a sweet, thick boost that is nearly transparent except for the enhanced low end response it gives the amp. When I use this pedal together with my modded TS9, I get a fat, thick, screaming solo tone that sounds better than anything I have every used before!
I also enjoy using the pedal to thicken or accent certain parts of songs. And it comes in real handy when I'm soloing and the band starts to get loud. In the past I would just tough it out with my TS9 and get through the solo. Now, I just kick in the clean boost on my KoT (on top of my TS9) and essentially, go to "11."
This pedal is a bit subtle at livingroom levels and it's true character doesn't come through until you're at a gig. When it's in it's element, it totally shines and is very useful.
As a traditional OD pedal, I'm not particularly amused. Not for the way I play and set up my gear. It seems that this pedal would work great for a little amp like a Champ that is already on the verge on an aneurism. Kick in the KoT and make it bleed! It seems like it may work very well in that application. Not for me.
The affect it has on my sound is quite transparent yet very effective. An extremely useful tool for a live gigging player. Worth the price of admission.
