Kinda sorta Thinline build
Discussion in 'Tele Home Depot' started by CraigB, Dec 16, 2019.
  1. CraigB
    CraigB Tele-Afflicted
    Central Coast of CA
    Never done a Thinline, been on my build wishlist for awhile, so when I was approached by an acquaintance wanting a T-style guitar that "has to be lightweight", my answer to that was "Thinline". A couple of his requirements rule out the recommendation:
    #1 NO F-hole
    #2 Tummy cut
    On the plus side, I get to build another guitar. Here's the plan:
    The neck blank comes first. Those Timberwolf blades are so good, even my cheap little bandsaw cuts like a champ. Not shown, ROSS'd close to line and trimmed on router table.
    Laid out and cut the Indian laurel fretboard
    Attached it to my trussrod channel jig and cut the channel in about six passes
    Drilled out the heel, a little chiseling for the adjustment end, got a pretty nice fit
    By this time it was getting dark, and as usual, the cleanup almost took as long as the woodworking!
    mkster, idjster, nickhofen and 7 others like this.
  2. Deeve
    Deeve Friend of Leo's Silver Supporter
    Ballard
    @CraigB - Looks like a good start. Will read the next progress reports w/ great interest.
    Peace - Deeve
    CraigB and crazydave911 like this.
  3. nosmo
    nosmo Friend of Leo's
    Lake Jackson, TX
    That's why I don't clean up :)
  4. Jim_in_PA
    Jim_in_PA Tele-Holic Silver Supporter
    SE PA near New Hope PA
    Neither of the two requirement eliminate being able to hollow for weight control. The belly cut makes for more work because you have to tailor the internal contour to account for the exterior relief contour, but it's very doable...in fact, there have been a few threads here that have showed folks contouring the internal pockets. Go for it!
    nickhofen, crazydave911 and CraigB like this.
  5. CraigB
    Central Coast of CA
    Taped the gluing surface off to prevent any chance of silicone getting on there, dabbed a little goop in the channel and dropped the t-rod
    Taped the sides and rolled out some glue on neck and fretboard
    Stuck in my index pins and clamped up. Got nice glue squeeze-out all the way around
    1bad914, Jim_in_PA and crazydave911 like this.
  6. CraigB
    Central Coast of CA
    Thanks, Jim! Yes, it'll be weight relieved for sure. I have seen the terraced interior routes to allow for belly cut and may do just that, depending on how much weight the lower chambers relieve. The body blank I have is already very light, just a little under 9 lbs. with nothing cut off yet, and it is 2" thick, so I'm going to have to thickness it as well.
    To my thinking, a Thinline has to have an F-hole, it just looks so cool, and so I'm mildly disappointed he didn't want one!
    crazydave911 likes this.
  7. CraigB
    Central Coast of CA
    Here is the top. Got it off ebay for a pretty good price. Kind of a mixture of curly, flamey, quilty.
    Planed the gluing edges and clamped it up.
    Planed and thickness sanded the body, screwed the template down and drew the outline
    And cut out on the bandsaw. Accidentally let the blade wander inside the line on the upper bout. o_O
    Love the Whiteside spiral router bit. Thankfully, there's only a couple little superficial cut marks where I veered off course on the bandsaw
    mkster, tigger, nickhofen and 5 others like this.
  8. CraigB
    Central Coast of CA
    Returning to the neck, used the SM tuner hole drilling jig to start the holes, then to the drillpress and complete the pilot holes.
    And just let the brad point poke through
    And bring it through from the backside
    And trim the fretboard flush
    And cut the fret slots
    That all went pretty well, until it started raining. Thankfully it started with a few sprinkles, just enough time to drag everything in before it started to pour!
  9. CraigB
    Central Coast of CA
    Here's my headstock thickness router jig. A couple protruding dowels for the E tuner holes with a wooden strip strapped across the 2nd fret location keeps it stationary. Simple, ugly, effective
    This was done in four very shallow passes
    And then ROSS in the transition
  10. IronSchef
    IronSchef Tele-Holic
    Flew here on my Dragonfly
    This is SO flippin cool - thanks for taking the time to document the whole thing w/ pics. gonna enjoy watching this one take shape!! :)
    CraigB likes this.
  11. RiversQC
    RiversQC Tele-Meister
    Quebec
    Two outta three ain't bad - I think I'm going to build one just like it!
    I'm working mostly outside too with a similar set of tools, there's just a bit less snow where you are...
    Looking good so far, that's some steady progress you're making.
    crazydave911, Jim_in_PA and CraigB like this.
  12. CraigB
    Central Coast of CA
    Drillin' for dots
    And glue 'em in
    And sand in the 9.5" radius
  13. CraigB
    Central Coast of CA
    Thanks, I'm really enjoying myself so far!
    Yeah, the snow would definitely be a problem! Wouldn't it be great to have a real workshop with heat, dust removal, etc.? Some of the members have such nice setups, it's hard not to be just a little jealous.
    crazydave911 and E-miel like this.
  14. fenderchamp
    fenderchamp Tele-Afflicted Silver Supporter
    omaha
    great thread!!
  15. CraigB
    Central Coast of CA
    Glue-up was a success. The two sides were not thicknessed exactly the same, so grabbed the 1/4" thick glass plate sanding beam and went to town...like two hours of manual sanding & wiped a little alcohol on it. Sure makes me want a drum sander!
    And cut close on the bandsaw. This time I stayed a little further outside the line. What a great idea ;)
    I hate doing this in the garage, but I couldn't let the rainy day stop progress. What a mess that made!
    By the time all the holes were drilled, there was a break in the rain, just enough time to cut out this template for the chambers
    And get it routed out. Literally ran out of daylight, my motion floodlights came on as I was finishing up the final route. This really lightened it up a lot. With the tummy cut and other small cavities, it should be just right
    And move back into the garage and get it ready to glue the top on
    Used my strat template and the tele template as clamping cauls. Once the squeeze-out started to appear all the way around, pulled the tape and let it sit overnight
    mkster, Macrogats, nickhofen and 6 others like this.
  16. gtrwrks
    gtrwrks Tele-Afflicted
    Oklahoma City, OK
    Can hardly wait to see the finished product. Killer job so far.
  17. Preacher
    Preacher Friend of Leo's
    Big D
    I would just like to say that building a neck is not as easy as this post would infer. Great job!! That neck looks fantastic!!
  18. CraigB
    Central Coast of CA
    Thank you!
    Roger that! When I get to this point without any major screwups, the anxiety level goes up ever so slightly :lol:
    You'll note, for now I've abandoned the neck and focused more on the body, lol...anywho, outta the clamps, it begins to look more like a guitar
    A little trip around the ROSS, and a spin around the router table, looks pretty good.
    I didn't forget about the neck completely, though. This is just one of those rainy day items that needs to get done at some point, so now's as good of a time as any. I use testor's model paint and a toothpick, a little drop on the end, lay it on in the wider openings, then drag through the narrower parts of the letters, kind of the reverse of drag'n drop if you know what I mean! The toner on the decal actually forms sort of a dam that holds the paint within its boundaries.
    Macrogats, Clint Walker and Jim_in_PA like this.
  19. idjster
    idjster VERY grateful member Silver Supporter
    Saskatchewan, Canada
    Such great work! I love it!
    CraigB likes this.
  20. CraigB
    Central Coast of CA
    Merry Christmas To All! Out of due respect for my wonderful neighbors, I promised to keep the noise level around here low for the next couple days. So handtools it is.
    Leveled the nut slot. Hardly a sound there
    Sanded the side dots flush and ran the pullsaw through to clean up and radius the fret slots. Fairly quiet
    A little three-corner file work to open up the top of the slots
    This thing makes no noise
    By this time, not hearing a sound emanating from the sideyard, my wife came out to check on me to see if I was doing OK :D
    And I went about my business
    Chopped off the ends flush.
    And a little markup to guide the carve
    a quite peaceful Christmas Eve day!
    mkster, Macrogats, nickhofen and 4 others like this.
