Just solved a pedal problem
  • Thread starter Heartbreaker_Esq
misterdontmove
Connecticut
You should also try keeping the core tone pedal always on, then a mid boost in front (ts 9, tumnus...the list goes on) and a cleanboost after (boss eq works great). Might be a little more consistent then the under driving method.
I do just this! SD1("mid boost" for leads)>OD3(modded for lower gain/always on)>SHO clone (set just above unity gain/not really a "clean boost" but you get the idea). Works like a charm. Even when I lower the guitar volume to clean up the OD3 the SHO keeps the volume and sparkle right where it needs to be.
misterdontmove
Connecticut
I bought a very cheap DIY kit called Lead Master. not much soldering going on, so anyone can get this done.
in/out jacks, a footswitch, 1 LED indicator for solo and a volume pot.
set the volume for normal playing, unleash full power switching to solo. 9volt battery just for the LED which lasts for ever.
What does it do? Throttle down the output a little and bypass it when you turn it "on"?
Alamo
Berlin
Exactly.
With "dicipline" ....you could archive the same effect by turning your guitar volume knob down for rythm and crank it for solo.
