Just picked up a 67 - 69 fender Bassman.
Discussion in 'Amp Tech Center' started by Shockmaster, Jun 4, 2020.
  1. Shockmaster
    Shockmaster TDPRI Member
    Los Angeles
    Just picked up a 67 - 69 fender Bassman stack. Grabbed it in good shape for $300 for the original owner. Only issue is it doesn’t power on. I had some sore fuses around and switched that, no luck, unless there’s another fuse in there I’m unaware of. What’s the next step I can take to see if it’ll power up? I know these things can be dangerous, I just want to give it a few tries at home before I take it to a tech. Any info is great Appreciated. Thank you!
    bftfender and Dismalhead like this.
  2. ReverendRevolver
    ReverendRevolver Tele-Afflicted
    Ohio (Nerk)
    I only recall the slo-blo in the back. Mine popped twice in 10 years. It turns out that a whole room in the house was wired with what appeared to be telephone wire, so a constant tingling feeling in my fingers periodically and 2 blown fuses was better than a dead me anda blown bassman......
    Unfortunately, it not turning on would involve troubleshooting from the power cord into the amp. But it's a great amp once it makes sound, congratulations!
  3. milocj
    Michigan
    Stupid question: have you checked to see if the tubes are lighting up and that you simply don't have a bad bulb? Those pilot lamp bulbs can have a habit of needing to have the contacts tweaked. Make sure a speaker cable is plugged in if you are trying to play through it.
    tubegeek likes this.
  4. Shockmaster
    Los Angeles
    not a stupid question at all. I checked. A new development is that every time I switch it on it blows the fuse. I had 4 fuses and they all blew. So definitely something going on.
    Dismalhead likes this.
  5. ce24
    ce24 Poster Extraordinaire
    Idahoastan
    Rectifier?
  6. Jack Clayton
    Jack Clayton Tele-Meister
    Phoenix, AZ
    Three hundred for that? I'm so angry at you right now...
    Lowerleftcoast and Shockmaster like this.
  7. Shockmaster
    Los Angeles
    Haha. I jumped on it as soon as I saw. They were asking $400 but took $300. It was a junk removal company. Apparently they went to empty a house that was going on the market and the owners said to toss it. So they decided to sell it and and I made the 80 mile round trip and picked it up.
  8. corliss1
    Lansing, MI
    If it's blowing fuses when you turn it on, it needs a tech. It needs a tech anyway for a full service before it's turned on again anyhow. No point in guessing at what could be wrong - get the service done and you'll have a killer amp.
  9. Shockmaster
    Los Angeles
    Noted. That will be my next move
  10. AlbertaGriff
    AlbertaGriff Tele-Afflicted
    Probably gonna cost another $300 to get it fixed up to being a "new" vintage amp, but it will be worthwhile.
    Shockmaster likes this.
  11. Shockmaster
    Los Angeles
    That’s a reasonable price. I was just hoping it wouldn’t exceed $400. I ran my hot rod deluxe iii Into the cab and the cab sounds great
  12. ucnick
    ucnick Tele-Meister Silver Supporter
    Union City CA
    I had one of those back in the 80s, but sold it prior to moving to California in '89, great amps!
  13. Lowerleftcoast
    Lowerleftcoast Tele-Afflicted
    california
    +1
    No point for a novice to go any further.
    Agree with corliss1 "No point in guessing at what could be wrong". I would prepare for the expense of a transformer as a worse case scenario.
  14. schmee
    It can be lots of things. But hopefully it shouldn't cost $300. .... unless the transformer is blown. I've bought two non working Bassman heads in the past and both were very simple things.
    Shorted power tube>Filter cap> rectifier diode or > bad tranny in that order.
    To avoid getting ripped off call around and ask how much a Filter cap job is on that amp. If they say over $150 or a bit more move on. That at least gives you some idea how that person charges.
  15. Burning Fingers
    Burning Fingers TDPRI Member
    There is only 1 fuse..a 2amp slowblow
    Some causes for blowing the fuse with standby off
    1: wrong fuse...you need a 2 amp slow blow fuse...a fast blow fuse will not do the job
    2: shorted power transformer ( Unlikely )
    3: Short in the power diodes and/or filter caps ( quite likely )
    Try the correct fuse but if that doesn't work then it's tech time.
    If it doesn't blow fuses with standby off but only when standby is on then forget about the above and look at
    4: Bad power tubes...does it blow the fuse with the power tubes removed ?..if so try new power tubes.
    Still can't find the problem...tech time.
    Good luck with it...great amps in my experience
  16. Dacious
    Dacious Poster Extraordinaire
    Godzone
    Try it with power tubes out, with correct fuse installed. Check if heaters in preamps light up.
    If it doesn't blow, probably bad tube. If it blows with power tubes out, could be bridge rectifier.
  17. Shockmaster
    Los Angeles
    Really appreciate all the info. I’ll be taking it to a tech in ah hour and we will see what he can tell me. He’s $65 an hour so hopefully he doesn’t need to spend too much time inside. If I’m all in $600 then I’ll be happy. The speakers in the cab look to be fairly recently serviced or re-foamed so i think we are good there. They sound great plugged in to my hot rod deluxe iii.
    schmee and Burning Fingers like this.
  18. Silverface
    Lawndale CA
    I can't quite read the serial number clearly, but it LOOKS like A44950, which would make it a '68.
    Anywhere from A 39000 - A 49000 would be a 1968, give or take a month.
  19. Shockmaster
    Los Angeles
    I’ll tell you the serial when I get the amp back from the tech.
    Silverface likes this.
