Just how hardheaded am I? (gonna buy a power planer)
Discussion in 'Tele Home Depot' started by mchet, Apr 17, 2009.
  1. mchet
    mchet Tele-Holic
    Kingston, PA
    I am going to purchase a power planer tonight.
    I hate to waste those pine blanks, but the manual planer and I do not get along. So I am going to get a power one.
    The pine has many unavoidable knots. Any suggestions, warnings, encouragement, before I let 'er rip?:twisted:
  2. jkingma
    44°55'09.9"N 79°25'39.1"W
    Admin Post
    Buy a thickness sander instead. ;)
  3. edd677
    edd677 Tele-Meister
    Ontario
    x2 those things are great
  4. mchet
    mchet Tele-Holic
    Kingston, PA
    Thickness sander = to much money...
    I don't own a drill press, yet, so getting the robo-sander setup is a waste of money.
    I know, well I hope anyway, that a belt sander will knock it down but I hate to waste money if it will just dent the problem not fix it.
  5. mchet
    mchet Tele-Holic
    Kingston, PA
    $40-$60 for budget belt sanders. Thinkness sanders, even those you build cost much more, well at least half as much...
  6. mchet
    mchet Tele-Holic
    Kingston, PA
    Dang it!!! Good advise is costly!!!
  7. Jack Wells
    Jack Wells Doctor of Teleocity Ad Free Member
    Albuquerque, USA
    The Ridgid thickness planer ($369) is probably the best buy out there. It has a 13 in. width capacity. Many are only 12 1/2 in. Not good for a Telecaster body which is around 12 3/4 in.
    ......[​IMG]
    Hmmm............ by power planer I hope you aren't talking about a hand held power planer.
    ...... [​IMG]
    That would be a big mistake.
  8. Mightyaxeman
    Mightyaxeman Tele-Afflicted
    Pennsylvania
    Maybe a jointer is what your looking for?
  9. mchet
    mchet Tele-Holic
    Kingston, PA
    Yeah, that is what I was thinking of...
    There is a planer similar to the Ridgid over at the local pawn shop, actually 2, for between $50 - $150.
  10. Jack Wells
    Albuquerque, USA
    It would help if we distinguished "power planer" and "thickness planer" ............. very different tools intended for different purposes.
  11. mchet
    mchet Tele-Holic
    Kingston, PA
    Please feel free to educate... I only have a palm sander at this point. I know a planer would be best, but money is tight so I have to find other ways. Harbor freight has a hand planer for $30-$40. Lowes or home depot have belt sanders for $60 and under (+ tax of course)
    What SHOULD I be using?
  12. mchet
    mchet Tele-Holic
    Kingston, PA
    Maybe an inventory of tools, not that there are that many...
    I have a B&D work bench, cheapest available, an old dresser about 4'L x 2.5' W, a hand planer (which I really suck with), a palm sander, and a 2nd hand Makita 3606 router. I also have a B&D Dremel knockoff, a B&D Jigsaw/Scrolsaw and a B&D cordless drill ( I have a corded drill somewhere but have not used it in years).
    Also the odd assorted handtools most people accumulate in a life.
  13. Jack Wells
    Albuquerque, USA
    If a thickness planer isn't in you budget at this time I suggest you look for a local custom cabinet shop. They would probably run your body blank through the thickness planer for a small fee.
    Here's another option. Look at Scatter Lee's thread on his jigs. He uses a router with straight bit to thickness plane his blanks. Very ingenious.
  14. mchet
    mchet Tele-Holic
    Kingston, PA
    Small town, surrounded by small towns. Only one place left within 50 miles that does that kind of work and I can seem to nail them down on when they are open.
  15. Jack Wells
    Albuquerque, USA
  16. mchet
    mchet Tele-Holic
    Kingston, PA
    Got SL's jig thread subscribed. I will look closer at it. I was looking at the jig he made for radiusing necks. I was having a hard time figuring out the jig for using the router as a planer.
    What about the knots? Should I avoid them with the router using it this way?
  17. mchet
    mchet Tele-Holic
    Kingston, PA
    THANKS J!!!!
    I hate to give up on the pine:neutral:
  18. Jack Wells
    Albuquerque, USA
    Basically it is two equal height rails that are just a little higher the the wood you need to plane. You need a way to secure the body or blank to the base. He uses a screw through a string through hole and probably through a neck mount hole. He does half the body then moves the string through screw to a hole on the planed side.
    The router mounted on the board is free to move side to side ........ forward and backward. You just need to make sure the board doesn't slip off the rails.
  19. mchet
    mchet Tele-Holic
    Kingston, PA
    So 2 19" long 2 1/4" wide board, of some kind, topped by the split PCV tube. How about 3/4" MDF? Can make a base board with the 2 1/4" high slats attach (maybe glued and screwed together)... I think I have the idea...
    Thanks A LOT!!!
    Gotta remember to thank Scatter for his sharing all this stuff!
  20. mchet
    mchet Tele-Holic
    Kingston, PA
    maybe I should drill out the knots and dole them...
