Just had a weird (maybe genius) idea for a Telecaster bridge that doesn't exist.
Discussion in 'Bad Dog Cafe' started by _MementoMori_, Apr 18, 2021.
  1. _MementoMori_
    _MementoMori_ Tele-Afflicted
    The Bible Belt
    Ever want to access your bridge pickup cavity without popping off your entire bridge? Well, what if you made a two piece bridge with a hinge that allowed you to pull your strings off, adjust your saddles as far back as possible, and then just flip a plate over the pickup cavity without unscrewing your bridge mounting screws? Here's a crappy sketch of the idea.
    Is there any reason this wouldn't work? Aside from the fact that I didn't draw a spot for saddles to install... say NOTHING about that! Haha. It's a minor revision.
  2. _MementoMori_
    The Bible Belt
    Here, before you guys make fun of me. I fixed the sketch.
  3. O- Fender
    O- Fender Tele-Afflicted
    The only possible concern I can see would be the hinge pin rattling. Probably an easy fix for someone smarter than me.
    But I like the idea.
    Steve Holt and Alamo like this.
  4. Alamo
    Alamo Doctor of Teleocity
    Berlin
    I like the idea but maybe one would encounter a microphonic bridge too easily.
    ScribbleSomething likes this.
  5. Chart72
    Chart72 TDPRI Member
    I think adjusting saddles as far back as possible is a no-go-if you keep the same setup, screwing the bridge back on is not a big problem because the intonation will be right, but having to move the saddles seems like an extra pain. If I wanted it to be easier to access that cavity I would just “cut the bridge in half” and screw both pieces on.
  6. ScribbleSomething
    ScribbleSomething Tele-Holic
    San Antonio
    I think you’d need to screw down the front of the bridge too. Even then it might have a tendency to vibrate too much.
    Maybe get one of the cutoff bridges and a humbucker plate the converts to tele. That way everything is screwed down.
    Festofish likes this.
  7. maj34
    maj34 Tele-Holic
    St. John's, NL, Canada
    Now you just need to go back in time and give the idea to Leo... :)
  8. galaxiex
    galaxiex Tele-Afflicted
    Edmonton, Alberta Canada
    Neat idea, but not sure how practical it would be.
    Been my experience that that the seemingly most insignificant tiny thing can cause buzzing/rattles and are next to impossible to track down.
    With a hinge you have introduced "one more thing" that could cause a rattle/buzz.
    TigerG likes this.
  9. Papa Rufus
    Papa Rufus TDPRI Member
    Colorado
    I'm a machinist. Hmmmmm......
  10. summer_69
    summer_69 Tele-Meister
    Denmark
    Not that I need it ... Still a cool idea.
    Why the hinge btw couldn't it just be two separate plates? Also, no need to remove strings. Just put a capo on, slacken strings and unscrew the neck. Instant full access - as you have on the front pu when you remove the pickguard screws.
    FenderGyrl likes this.
  11. kennl
    kennl Tele-Afflicted
    Moon Township, PA
    seems to me that the cavity can be accessed with a stock bridge by removing strings and 4 screws
    your plan is to move all the saddles (3 or 6 screws). which will need to be relocated when restrung
    that part makes the hinge less advantageous
  12. Brad Pittiful
    Brad Pittiful Doctor of Teleocity Ad Free Member
    Philly Burbs
    why hinge it...just have a two piece
  13. _MementoMori_
    The Bible Belt
    Yeah, two plates that both screw into the body achieve the same thing and not at the expense of moving the saddles. I like it!
    ScribbleSomething and Papa Rufus like this.
  14. summer_69
    Denmark
    Thinking about it for pickguards and maybe this bridge pu plate you dont need screws. Two dowels for location and a few of these horribly strong permanent magnets might do the job with a magnetic insert in the plastic parts.
  15. Alamo
    Berlin
    Status Quo's Rick Parfitt must've had the same thoughts
  16. summer_69
    Denmark
    Or - a trivial and boring idea - introduce a body routing so you have access from the back. Then you dont need to remove anything but a back cover.
    Steve Holt likes this.
  17. Festofish
    Festofish Tele-Afflicted Silver Supporter
    Grand Rapids, MI
    Do you have an un-hinged model? :) Seriously though it looks like a better mousetrap that you could design with a cheap bridge, a saw and a hinge. Go for it!
  18. Alamo
    Berlin
    or Francis Rossi's
  19. GuitarsBuicks
    GuitarsBuicks Tele-Holic
    Somewhere between here and there
    That is a relatively good idea but there are a couple of problems. I like the general concept but I feel the need to point out some of the problems I foresee. One being as mentioned that the hinge pin could work its way out. The second would be that it opens you up to changing pickups much more often...which while it may be okay for some, does not force you to actually learn how to work with the pickups in a guitar that you have. Thirdly, Telecaster bridge pickup routes tend to be rather tight around the pickups, this meaning that when you flip up the bridge it is going to catch on the body. Fourthly, many bridge pickups have relatively short wires so you would need to make solid leads coming from the switch...also you still have to unscrew the control plate to attach the pickups to the controls unless you were to come up with an alternate wiring system. Finally, how are you intending to hold the front part down as it could easily flip open due to either gravity, your fingers, or centrifugal force while playing.
    Fendereedo likes this.
  20. Festofish
    Grand Rapids, MI
    No way...Become Leo and build the Jubilee!!! No that’s crazy.
