%&$#!!!- Just broke another D string!
Discussion in 'Telecaster Discussion Forum' started by Tarnisher, Oct 1, 2014.
  1. Tarnisher
    Tarnisher Friend of Leo's
    Brooklyn
    I never ever used to break strings on my Tele, but last week during band practice, the winding on my D string broke at the bridge. I was just strumming, not even especially energetically.
    I chalked it up to going way to long without changing strings- I'd been playing acoustic all summer. But while practicing just now, the same thing happened (on the same song, even). Again, I was not playing that aggressively- it's a midtempo song and I play a simple rhythm part. This time the string had no more than 4 hours of action.
    I have a gig Friday, and was really planning on playing my Tele, but I don't want to risk a string break in the middle of the set.
    Anybody have any advice?
  2. Tarnisher
    Brooklyn
  3. Lerb21
    Lerb21 Friend of Leo's
    New Florence, PA
    Check for a burr on the saddle.
  4. Sea Devil
    Sea Devil Tele-Afflicted
    Brooklyn, NY
    It kind of looks as though it broke where the string emerges from the bridge plate, as opposed to on the saddle itself. I'd look for a rough spot there.
  5. KMBkelly
    KMBkelly TDPRI Member
    Newman,CA.
    Yup, just a burr. Not a big deal. I agree it's probably your bridge plate but you oughta check the saddles too... if you have a vintage bridge, you could have a string rubbing on a saddle adjuster screw (been there). As for Friday, if you don't figure it out, just bring a backup guitar.
  6. rasm0225
    rasm0225 TDPRI Member
    Saint Paul
    Wow, you play with a wound G? I haven't run into that before, but maybe I live a sheltered life.
    Is this common for tele players on the forum?
  7. Tel E Twister
    Tel E Twister Tele-Meister
    No, a wound G is not common. I was gonna suggest a lighter pick, but then I realized it said G, saw it was wound, and I went WTF!
    What's up with that Tarnisher?
  8. KMBkelly
    Newman,CA.
    I used to use wound G's on all of my electrics. They sound waaaay different to me than a standard (not wound) string. I couldn't find them anymore so I switched to regular old strings.
  9. trashedlostfdu
    trashedlostfdu Tele-Meister
    Tampa, FL
    i agree with every word. especially look to see if it is riding the saddle adjustment screw. i had a tele that did that really bad.
  10. MickM
    MickM Friend of Leo's Platinum Supporter
    A steel guitar engagment.
    I use GHS Nickel Rollerwound 11-50, they have an
    .018 wound G. Never had one unwind like the op.
  11. Tonetele
    South Australia
    Some of us old guys can remember back to the 60's where a) lucky to get strings and b) the G was always a wound string. I never could get used to a set like 9-42s. JMHO
  12. MickM
    Yea, yea!!! And we had to walk to the music store up hill both ways!:lol: You're right, mostly Black Diamond and Mapes and Fender? I don't remember having a choice of gauge or even buying complete sets. I used to change 'em as they broke; didn't know better!
  13. unixfish
    unixfish Doctor of Teleocity Silver Supporter
    Northeast Ohio, USA
    The wound G is a great trick to tame the harsh, buzzy, breakup sound the G makes - especially on a Strat. When I was running 11's on my Strat, I preferred a wound G. When I switched to 10's, I still get a bit of that buzzy breakup sound from the G string.
  14. Tarnisher
    Brooklyn
    What's up? I was tired and peeved, and somehow got it into my head that it was a G string. It's actually a D. I think it's because I've been playing acoustic so much that my brain just made the leap that the last wound string = G.
  15. Tarnisher
    Brooklyn
    Anyway, back to the breakage. As you can see in the pic, the break seems to be right over the saddle, so I don't think the bridge plate is involved. I don't see a burr, but I didn't use a magnifying glass. If it is a burr, how do I fix it? I tried pulling the string back and forth over it- would that do the trick?
  16. Diamond White
    Diamond White Tele-Meister
    Essex. UK
    I wouldn't have thought a burr would snap the core of a wound string. It would have to grind through the winding first, that would be some burr.
    Might be a bad batch of strings?
  17. tlimbert65
    tlimbert65 Tele-Afflicted
    Northwest Iowa, USA
    I love what a wound G did for my Tele with the 3-saddle bridge. Improved the intonation, and balanced the sound of the strings. What I don't like is not being able to bend that G very easily.
  18. Tel E Twister
    Alrighty then, now that we know there are plenty of wound G users out there, I would still suggest a slightly lighter pick and/or slightly heavier string(s). I had the same problem long ago. I had no burrs. I switched to 9-46s and a .60 pick and the breakage stopped. It took me a while to realize that I play kinda hard.
    Simple metal fatigue.
  19. stnmtthw
    stnmtthw Friend of Leo's
    New Mexico
    Get some fine grit sandpaper and give it a couple passes on the inside of the saddle, where the string rides. Use something small enough to fit inside the saddle to put pressure on the sandpaper- a small metal rod or something like that. It doesn't take much.
    And, FWIW, just because you can't see the burr doesn't mean it's not there.
    Hope this helps.
  20. Tarnisher
    Brooklyn
    Well, I made it though the gig with no breaks.
    I'll try some sandpaper just in case, but I'm reluctant to change string or pick gauge, especially because this was never a problem before.
