Joyo Ultimate Drive Too Loud!! HELP!!
Discussion in 'The Stomp Box' started by steveneddy, Nov 26, 2013.
  1. steveneddy
    steveneddy Tele-Meister
    I love my Ultimate Drive - best $35 I have ever spent.
    The other day I dropped it - and it still sounds good - but it is WAY TOO LOUD!!!
    I can only get it to the 9:0'clock position before it is way louder than the clean channel - WAY too loud!
    I know it is a distortion pedal - but if I crank up the amp for a good clean sound to be heard over the band - then step on the Ultimate Drive pedal and it is turned up past 9:00 - WAY TOO LOUD!!
    What do you think I did?
    I pulled the board - checked the pots and they all seem to measure correctly with no jump in resistance. All of the components look OK also - nothing loose or broken off.
    I haven't checked the IC chip - I don't have a scope here.
    Any suggestions?
    Here's the schematic.
    Thanks in advance.
  2. Paul G.
    Paul G. Friend of Leo's
    Rhode Island
    I'm thinking you knocked one of the clipping diodes loose.
  3. steveneddy
    I don't see any diodes in the drive circuit.
    I went ahead and purchased another one - and if it works like the first one did when I first got it then I'll use that one.
    This will give me time to repair the first one.
    Looking at the schematic I think it is the TL082 - but I will probably check all of the resistors - check the one diode I see that's not a rectifier diode - maybe it's Q1 or Q2 also - I don't know how to repair it or diag the issue without a scope.
  4. italo
    italo Tele-Meister
    Argentina
    make sure you are not putting 12 Volts in it. Check your voltage!
  5. Iago
    Iago Friend of Leo's
    Brazil
    I've messed with my UD quite a bit. Here's a tip:
    Replace the stock 500K pot with a 100K Log pot. Note that you should use those "mini" ones, 9mm or so. That should give you unit volume at about noon.
    Diodes have nothing to do with that. Unsoldering or clipping the 1N34 diode will make the pedal cleaner tho, removing that extra fuzziness.
    By the way, I don't think yours is broken, these pedals are loud - you get a lot on the first quarter turn of the pot, not all that much after that.
  6. steveneddy
    All GREAT suggestions.
    I will wait until the replacement pedal comes and then re-evaluate whether or not the pedal is damaged. I should receive it on Friday.
    If this is simply the way they are built I will determine an appropriate mod to tame the output volume a little.
    It is perfect if this pedal is on all the time and you never deviate from this sound.
    I love the sound of this pedal - great tone and touch dynamic in a good way.
  7. k tone
    k tone Tele-Afflicted
    Unity volume on mine is 9:00 as well.
  8. steveneddy
    Ah - so on to the mods to get the output volume to a controllable area of the pot.
    stay tuned - more to come.
  9. k tone
    I just leave mine around 9:00 ;) ??
  10. valvestate
    valvestate Tele-Afflicted
    Land of the Merlion
    Yup... same here... ic i really want to get crazy over the top loudn3ss, i set it to 10 pm :lol:
  11. steveneddy
    Both pedals are the same - so I didn't break it when I dropped it.
    I still feel like I need a little more control - 9:00 is plenty loud - but a crank more and it's too much over the top.
    I need more fine adjustment with more pot travel.
    I have given it a lot of thought - what I have decided to do is since a 500K pot is too loud at 9:00 - I will install a 250K pot - which should give me the pot travel I am wanting with a finer adjustment in the overall loudness from the pedal.
    I am using this pedal live and I like it on rhythm and lead tones - cranked for leads doesn't help me on the rhythm parts - it's too loud even with my guitar volume turned down.
    I would use a different pedal but I love the sound of this one - you know how it is - you find a sound you love and you gotta stick with it.
    As soon as I find a 250K pot that will work in this application and install it I will post back with the results.
    Another alternative would be to change R6 to a 15K to 22K resistor - but it may make the negative feedback circuit on that TL082 cause a little feedback in the circuit - and it is getting over my head there.
    If nothing else works here - I have two now - I could use one for rhythm and the other for a lead sound - I'll post back with my final solution soon.
  12. charvel74
    charvel74 TDPRI Member
    CA
    I just got this pedal yesterday and im experiencing the same thing with the volume. Anything pass 9 o clock and its way too loud vs the clean sound. Why is it in many youtube demos the volume is closer to noon or n 1 o cllock. Has any one figured this out yet?
  13. FenderBender10
    FenderBender10 Tele-Holic
    Pacific Northwest
    Can you still keep the pedal at unity volume at 9? If so what's the problem? Wether it's at 9 or 3 as long you can set it at unity or a little higher i dont see why it's an issue. My ARC soothsayer is very loud, it gets to unity almost right after the I turn it up from 0. But it sounds great and at least I don't have to crank it all the way up and barely get to unity like some fuzzes out there.
  14. cousinpaul
    cousinpaul Friend of Leo's
    Nashville TN
    You could just solder a 470k resistor across the outer lugs of the volume pot.
  15. Mike Simpson
    Gilbert, AZ (PHX)
    I bought a Joyo UD and I didn't like it. It is harsh and "woofy". It has very little use, an hour or so. Sadly given the price new it is hardly worth anything used.
