Joyo Sweet Baby Tweed Champ clone
Discussion in 'Amp Central Station' started by teza, Jan 12, 2016.
  1. AJBaker
    AJBaker Friend of Leo's
    Switzerland
    It's pretty easy actually. There's an empty spot marked c7, and that's where the cap goes. It's strange they don't put it in. It looks like they designed the circuit board with that cap, but then decided to drop it to conform to the old (faulty) schematic.
  2. Alamo
    Alamo Doctor of Teleocity
    Berlin
    the circle left to those three resistors is marked as C7
  3. AJBaker
    Switzerland
  4. teza
    teza TDPRI Member
    France
    Thanks for this. Just did order the cap.
  5. teza
    teza TDPRI Member
    France
    What tubes are you using ?
    For me Nos
    Sylvanis 5ygtwa brown base
    RCA 6v6gty brown base
    RCA 12ax7
    Also got a RCA 6vgt black smoked black plate.
  6. teza
    teza TDPRI Member
    France
    Hi,
    See below the answer from Joyo when you ask them for the schematic of the Sweet Baby.
    "Hi Sir,
    I am sorry that the schematics are company confidential documents, we don't give out! hope you can understand.
    Any questions on the JTA-05, pls don't hesitate to let us know!
    Best regards."
    Unreal for me as they did stole it from Léo.
  7. teza
    teza TDPRI Member
    France
    Did you remove the board to put the cap or did soder it straight in ?
    Thanks.
  8. AJBaker
    Switzerland
    I soldered it straight in, but it was tight. Also, a radial cap would have fit better than the axial one I used.
    I'm not thrilled by the stock speaker. At low volume it's ok, but it farts out when I turn it up.
    I ran it through an eminence 1258 and it sounded much better (obviously). A better 8" might be in the cards some day, but I'll wait for now.
  9. teza
    teza TDPRI Member
    France
    I put a Weber alnico 8' signature smooth cone, not expensive and sound great. I'am thinking to buy a extention speaker cabinet 10' or 12' not sure yet.
    But when it comes to vintage sound like alnico.
    Thanks again
  10. teza
    teza TDPRI Member
    France
    I will try with the Weber 12" alnico have got in my Blues Junior before making a choice.
  11. teza
    teza TDPRI Member
    France
    Below is the config of the Victoria, so you right about cathode.
    • 5 watts of power
    • 5F1 Type Circuit
    • Single Ended Operation
    • Cathode Bias Design
    • Standard Speaker: One Jensen P8R
    • Standard Covering: Tweed
    • Tubes: 1-5Y3, 1-6V6GT, 1-12AX7
  12. AJBaker
    Switzerland
    I think they're referring to the output tube being cathode biased (the input tube is cathode biased regardless of whether a cap is there or not). But I don't know how Victoria does it, does anyone have a schematic?
  13. AJBaker
    Switzerland
    ...I found a picture! Victoria amps does indeed use a cathode bias cap, but I don't know what value.
  14. Alamo
    Berlin
    Uncle Doug talks about the cathode bypass cap - interesting.
  15. engineer
    engineer Tele-Meister
    Sweden
    I had a Celestion Super-8 in mine which was a decent speaker.
    I replaced it with a Jensen C8R 4 ohm speaker. You could also go for an AlNiCo one.
    BTW, the mod you did looks different from the one @andyfromdenver mentioned in the other thread.
    http://www.tdpri.com/threads/cheap-champ-from-china-joyo-fame-jta-05.625485/
    He talks more of putting it on the R4 resistor which is just to the left of the C7 position.
    But maybe there is no difference on that position? I wouldn't know.
  16. AJBaker
    Switzerland
    Same thing, I checked first with the meter.
  17. teza
    teza TDPRI Member
    France
    Hello Al
    Is the cap must be 25v whatever his value ?
    Cheers.
  18. AJBaker
    Switzerland
    25v is what's recommended as a safe value I believe.
    For the uF, 22 will pretty much amplify everything, whereas something like 0.68 will amplify the highs more, like on a Marshall.
  19. csbluesman
    csbluesman Tele-Meister
    Chehalis,WA
    It can be higher voltage but not lower than 25v.
  20. Alamo
    Berlin
    I just did it, soldered in a 22 uF, 25 Volt radial cap --Wow, did that get so much louder?
    I should have done more listening before/after mod but perception tells me it's a loud, snarling beast in a good way.
    with a 10" and 8" in my Deluxe sized cab it's absolutely gigable.
    very cool, good that we talked about it.
    thanks
