Snfoilhat
These cabinet photos look great, the colors and composition and the sort of 45 degree exploded diagram style. Thanks for sharing this
Well shoot, maybe I should be building the EF80 version. No wonder it’s being talked about so much. I guess in order to do that (besides ordering different tubes and other small parts) I‘d need a different power transformer. If the MT 18w TMB kit ever comes I won’t really lack on power option though.Yes, @joulupukki, you're right about the EF80s -- Rob has said he recommends the 12AU7 version for folks who want a true bedroom amp, as the EF80s (nominally ?2.5W) can run SPLs in the range of some 5W amps. Ask anyone who's tried to convince a spouse their Champ is great for bedroom use...
Or maybe since you'll have a big amp soon enough, a true Micro that gets distortion at reasonable levels would be a useful addition to your amp stable...Well shoot, maybe I should be building the EF80 version.
Exactly. I re-read Rob’s Bassman Micro site and if I’m understanding it right, the 12AU7 would be around a 3-4 watt amp, using a 12BH7 would be 4-5 watt, and the EF80 is around a 2 watt amp. Am I missing something there (different than what I stated earlier)?Or maybe since you'll have a big amp soon enough, a true Micro that gets distortion at reasonable levels would be a useful addition to your amp stable...
About the “Bassman Micro LTP EF80”:The 12AU7 with both triodes in push-pull will develop around 3 to 4 watts of output power. Swap in a 12BH7 and the output increases to 4 to 5 watts.
This version of the Bassman Micro LTP uses two EF80 novel pentodes in push-pull for true pentode power tube overdrive with about 2 watts of output power.
I’ll definitely be putting in this volume knob.I built mine with the post PI MV and it works a charm. Maybe not right at the bottom end of the scale, but it’ll take the majority of the volume off while maintaining a good tone. I mainly use it for keeping a constant volume between playing clean or dirty. I use an attenuator to do the grunt of the work.
Good to know. I won’t worry about adding the SS option and just keep it tube-based. Thanks for that info.I also added a Diode/Tube rectifier switch and can’t tell which is selected without looking at the switch position.
I’m not sure it’s possible to use a figure that will replicate a JTM level of negative feedback vs a bassman level etc. the power sections are just too different in my humble opinion. I found a figure that made the presence control work well and did away with the switch.
Great looking head cab by the way!
Thank you. Yes I did a 1/2" roundover. I maybe should have done 3/4" but that bit that I have for my router isn't the best. I actually used the Porter Cable dovetail jig with a router to do the finger joints (just using a straight 1/2" bit). It's maybe a little slower than a dado stack, but it works just the same. I'm excited to get the electronics put together.Beautiful work on the cabs, I really need to get on with doing mine for my JTM micro.
I wish I had access to a table saw that could run dado stacks, it would make finger jointing so much easier but it's not easy to get hold of them in the UK (yet..... although it might be soon with safety standards changing)
What size round over bit did you use? 1/2"?
I used this for the gold piping:What piping did you use?
