Lowerleftcoast
Quick and easy... cheap way. Leo's way.So why doesn't the 5F6A schematic have the same thing?
The popular mod is to change to what you are playing with.
As I understood, the Marshall JTM45had scratchy presence pots because this design.Hehe. Got it. So why doesn't the 5F6A schematic have the same thing?
With the Hammond 125B the 8ohm and 16ohm tap are the same, aren't they? 8ohm uses pins 2 and 4 (4 is the yellow wire). The 16ohm combination would be 1 and 4 (still yellow). That's where I've got it connected. To be honest, this OT is a little confusing because it doesn't have a common wire with dedicated taps.Sorry, remembered another thing. Mine is on the 16ohm tap so it would be JTM spec if Rob's work is correct.
I have it hooked up right now with a 50K mini pot between the OT yellow wire and the presence knob using alligator clips and a breadboard for testing (the mini pot drops right into the test board). If I set the pot to 1K and then, with my looper running, connect the wire to the presence knob (with the presence knob turned all the way down), I can tell a very small difference. It's a teeny bit louder and maybe a little more raw with it not connected vs. when I have it connected. The difference is so subtle. I do hear barely a difference with the presence knob as well. It just barely rolls off some of the highest end treble. Doing this test with it plugged into the PR's 10" speaker.Another thought—the effect of the NFB will be maximized when the presence is all the way down… IE maximum resistance through the .1u cap. If you turn it all the way down, does the NFB switch make a more apparent change?
I treated the yellow as the common wire so the nfb is connected to 1. I found a topic where Rob explained how to do the 16 ohm. It's described nowhere else but I stuck with it.With the Hammond 125B the 8ohm and 16ohm tap are the same, aren't they? 8ohm uses pins 2 and 4 (4 is the yellow wire). The 16ohm combination would be 1 and 4 (still yellow). That's where I've got it connected. To be honest, this OT is a little confusing because it doesn't have a common wire with dedicated taps.
On mine, I used the first number (wire) from the chart to connect to ground and the second to the speaker output tip. In this case, yellow (#4) is connected to the tip (NFB) and orange to ground. Is that right?Which OT wire connects to ground/chassis and which wire to NFB?
Nice. I know between 8 ohm and 16 ohm yellow can be used for both so yeah, that kinda makes sense, but between 4 and 8 it’s not shared. I dunno.I treated the yellow as the common wire so the nfb is connected to 1. I found a topic where Rob explained how to do the 16 ohm. It's described nowhere else but I stuck with it.
But now it's a regular OT so a true 16 ohm tap
