Jointing Highly Figured Maple
Discussion in 'Tele Home Depot' started by goodchicken, May 27, 2019.
  1. goodchicken
    goodchicken TDPRI Member
    US
    I couldn't get my jointer to not chip out some of a 1/4" flame maple top, so I've stopped as to not possible ruin this top. I'd like to hear some of your methods of jointing highly figured (chippy) wood w/o the jointer.
    Thanks!
  2. G.Rotten
    G.Rotten Tele-Holic
    CoolsVille
    A known flat/straight surface with stick on sandpaper. The challenge is keeping it at 90. Can hold against a squared block that is sliding beside sandpaper.
    Flush trim router bit, work pc fixed to known straight edge (may not chip as bad as jointer).
  3. Cysquatch
    Cysquatch Tele-Meister
    Grovetown, GA
    I would say a jointer is probably still the best option. How old are the cutters? Might be worth it to invest in some fresh, super sharp ones I'd the ones you're using have some age on 'em. What's your cutting depth set to per pass?
  4. RickyRicardo
    RickyRicardo Friend of Leo's
    Calgary, Alberta
    I joint the edge then I do it like this. Never an issue and as tight as can be. Around 6:00..
  5. Jsil13
    Jsil13 Tele-Holic
    Boston, MA
    Thank you for this. I have a book matched set of maple just like this and couldn't figure out how to joint it with limited tools. This looks like it will work great.
  6. guitarbuilder
    Some guys wet the wood with water before surfacing. You can also get helical cutterheads.
    eallen, Luthi3rz and PingGuo like this.
  7. Ripthorn
    Ripthorn Tele-Afflicted
    Austin, TX
    I use a high angle hand plane set for a shower fine shaving. Leaves a surface like glass.
    Bendyha likes this.
  8. Freeman Keller
    Freeman Keller Tele-Afflicted
    I don't own a jointer and I never mastered a plane and shooting board. I simply put some 120 grit sandpaper on a flat surface and rub the boards back and forth
    ps - I'll add that I join every top and back for every guitar I make this way - they all come out perfect
  9. TRexF16
    Tucson
    I'd avoid water - denatured alcohol is great to set up end grain for planning, might work here.
    And speaking of planning, hand planes are the answer here though many folks don't have them.
    Rex
  10. TRexF16
    Tucson
    Looks like a great technique that almost anyone could use.
  11. Freeman Keller
    The other little trick I learned is when actually joining the plates I put them on a flat board with waxed paper under them. I put a long thin piece of wood under the waxed paper right at the seam (a yard stick is perfect). Lay the plates on the waxed paper and clamp two long straight pieces of wood on each side. Remove the plates, apply glue to the seam, lay them back between the outside pieces, then pull the yardstick out and clamp the seam down with flat boards and waxed paper. When you pull the yard stick out it is just enough to tightly close the gap and makes aligning the figure easy.
    The backing piece of plywood is sitting on some little wood blocks so I can get the jaws of the quick clamps under, the deep throat clamps holding the plates down are Ibex bridge clamps
    peeweepete and Jsil13 like this.
  12. Vizcaster
    Vizcaster Friend of Leo's
    Glen Head, NY
    Freeman's solution is very elegant, and it shows how important it is to have a flat reference surface on your workbench. If you have a jointer, try sliding the fence forward to cover up the first inch of the blades so now you're edge jointing with a fresh area of the jointer blades for critical work like this. And take a lighter shaving than you normally would.
    I haven't found a need to dampen figured wood when edge-jointing but it certainly is useful for the planer.
  13. Freeman Keller
    Thanks, Viz, but I didn't think my method was at all elegant - pretty much brute force. Since I most build acoustics, there are two sets of plates that have to be joined on every guitar. I don't own a jointer so I usually clamp a thick straight beam to the plates right at the edge and route a tiny bit off to true them up. The the carpenter's level with sandpaper trick holding the plates flat against my workbench (which really isn't all that flat). Glue them up as above, then slap them in a radius dish and add the braces to hold everything more or less aligned. The plates are thin, less than 1/8 so the tend to be pretty floppy and the glue seam is very weak. Its nice to do a thick electric drop top for a change
  14. Honza992
    Honza992 Tele-Meister Silver Supporter
    Nottingham, UK
    I've never had any luck with jointing using a jointer. I think the tables need to be flatter than mine to get an invisible join....
    So, I use a Stewmac straight edge taped to the top and run it along a sharp guided router bit in the router table. It's good enough to go straight to gluing with nothing else needed. I use the tape/tent method to glue, which is more or less, the same as Freeman's above, but with tape.
  15. old wrench
    old wrench Tele-Holic
    corner of walk and don't walk
    The "tent" method is an old cabinet makers trick that's been around much longer than I've been :).
    Freeman's way of joining is elegant, in it's simplicity. No fancy or expensive stationary shop equipment required. The results speak for themselves ;).
    Best Regards,
    Geo.
  16. Luthi3rz
    Luthi3rz Tele-Meister
    AZ
    What I do is stick the pieces to a MDF backing board "Sled" 3/4thick and send it through a Thickness Planer
    So Are you trying to Thickness it?
    You either...
    A. Put it on a Sled Board and run it through and Thickness Planer
    B. Run it through a Thickness Sander
    C. Hand Plane it.
    D. Use a Router Jig to thickness it.
  17. Ripthorn
    Austin, TX
    When using Freeman's method (now official name :) ), it is important to make sure you have well mating edges. If you use a single reference edge, like a straight edge with sandpaper, make sure the edges are nice and square. With a hand plane, you can match plane (or plane both pieces at the same time) and the requirement for square is not needed, as the angles will be complimentary.
  18. guitarbuilder
    The "tent" method was shown in the Sloane or David Russell young books in the 1970's. A similar method was to use wooden wedges in what was like a printer's movable type frame ( before computers...LOL)
    http://nauglerguitars.com/kampguitar/?p=18
    This is what I did my first top and back with at GRD which is very slick and the traditional way to do it.
    Luthi3rz and RogerC like this.
  19. goodchicken
    US
    Well I used Freeman's simple method and it seems to have worked great! My jointer is new, hardly used it much yet, but it has worked perfectly on all the non-figured wood I had used so far...but I think I'll stick with the "Freeman Method" on figured pieces from now on ;)
    Thanks all for the comments. I really do appreciate all types of input!
  20. mefgames
    mefgames Tele-Afflicted Platinum Supporter
    North Bay, Ca
    And there you have it !!!
