JJ6v6S and the 70% bias rule
misterdontmove
Connecticut
So, I just purchased a pair of these and stuck them in my Ampeg Jet j-20. It's sort of a Brown Fender Deluxe clone with non-adjustable, fixed bias. It runs over 400 volts, and I previously cooked a pair of Tungsols in it. The JJ's sound GLORIOUS, but they're running 400 volts and 29ma, for just over 80% dissipation, according to Rob Robinette's bias calculator considering them to be 14w tubes (as indicated on the data sheets).
All the research I've done seems to support that they'll function at this setting and again, they sound really good with no sign of red plating, even after 3 hours of play at full band levels. Some of the stuff I've found, including some torture testing by Lord Valve (I think), indicates that these things are nearly indestructible (I said nearly)! And, some of the stuff out there would suggest that they may be 17 or even 19 watt tubes (more akin to a 7591 or 6l6gb). Interestingly, Rob's calculator also has 15w to 19w listed under tube type. If I pick 17w the dissipation falls right on 70% dissipation.
Anyone else using these tubes like this? Maybe we all should be! I will report back on longevity.
schmee
I have used them all the time for years. My BFDR and BFD run at 460-465 volts! I used to bias at 22-25 ma and they were fine. Now I bias at closer to 15 ma. But I may move up a bit as I wasn't using a calculator specifically for JJ's like Rob's.
schmee
By the way, I modded my BFDR to 6L6's a year or two back. (basically a Vibrolux) The result was I found that JJ 6V6's sound nothing really like 6L6's. I think I understand people saying that though, but the difference is huge. The JJ's do have a tiny bit cleaner edge to them than normal 6V6's, but still smooth like most 6V6's compared to spanky clean 6L6's.
No457 Snowy
I agree as I've found the same to be true. I have a Trinity Tramp that allows swapping between 6V6 and 6L6GC, and the JJ 6V6 sounds markedly different to any 6L6GC I've compared it to in that amp. I think a lot of people just repeat what they read and I've noticed in any thread about the JJ 6V6 before long someone will come along and say "it's not a real 6V6" and I have no doubt most of these people are just repeating what they read and could not articulate as to why "it's not real 6V6".
Commodore 64
Kent, OH
Proof is in the pudding, I guess. I redplated a set of JJs at 90% cathode bias at 375V. If yours aren't redplating, then carry on!
flyswatter
I've used the JJs in a bunch of repairs where the dissipation was 14W or more and other tubes were red-plating. For example, I had a SF Champ in recently, single-ended that has a stock B+ value of 420 VDC. The Tung-sol in the amp was glowing red. A JJ 6V6S fixed the problem.
robrob
United States
70% for fixed bias Class AB amps isn't a hard and fast rule. Merlin believes the max is really closer to 80% for normal tubes. With modern production tubes it's probably prudent to stick with 70% max with the exception being the JJ6V6S. it's a beast.
Henry Mars
Bucks Co. PA
There is a tendency to try and coax more out of 6V6 and 6bq5 (EL84) tubes than maybe we should ...sooo they tend to run "hot" in guitar amps. If it sounds good and the tubes don't look like they are melting down you are probably ok. Just keep spare tubes around. I have amps with 6v6 and EL84 tubes ... I either carry spare tubes or spare amps with these guys.
DADGAD
SoCal
I'm running a pair of JJ 6V6S tubes in my 70's Silverface Deluxe Reverb. They are idling at 25ma with a 5U4 rectifier. Cranked, the DR breaks up a lot like my 67 Bandmaster. I believe the JJ's sound more like a 6L6 than the RCA, KenRad and GE 6V6 tubes I have run in my DR.
/2 cents
misterdontmove
Connecticut
That puts me close even if I consider the JJ6v6 to be 14 watts. Second consecutive 3 hour practice and they're not breaking a sweat! No sign of redplating in a dark room, and they sound great. Thanks for all the responses!
misterdontmove
Connecticut
/2 cents
I agree! I have a Super Reverb and the J20 response is similar at lower volumes. The JJs are a little rounder and clip a little softer but are very 6l6 like. I may even like them a little better.
archetype
Fiend of Leo's
Western NY
Interesting. Thanks for the first-hand account.
DrivinSouth
Midwest
Every amp should be properly biased, and that even includes cathode-bias'd amps.
Get to the root of the problem and bring the amp to a tech and have him install an adjustable bias so that the amp can be biased correctly.
What you have right now is a wing-and-a-prayer that new tubes won't red-plate and blow.
jhundt
Netherlands
"get to the root of the problem"? What was the problem again? He said the amp sounds 'glorious' with JJ 6V6's in it. 6V6's in and amp designed for 6V6's. With no adjustable bias, but they sound GLORIOUS!
It sounds to me like there is no problem at all!
The only problem may be that the OP is worrying too much about numbers on a graph, and not taking the time to play that glorious-sounding amp. It's not about numbers, it's about the sound. The numbers are there to help the designer; this amp was already designed a long time ago. And apparently it was well-designed. Why try to rethink all that?
budglo
NE Ohio
I have the JJ 6v6S tubes in both my 68 Princeton Custom and my 65 DRRI . I biased them at around 70 percent and they really sound great.
misterdontmove
Connecticut
Oh its getting played! Almost daily at home volumes (LOUD) and 2x weekly at rehearsals at stage volume. The JJs are not even breaking a sweat. I really didn't get caught up in the numbers. My point is, after doing a lot of research, there is evidence to support that the JJs are capable of higher wattage. In almost every case you see the term "they are not a true 6v6" or they are more similar to a 6L6. In any case, if these tubes are actually 18 or 19 watt tubes, they're not running over 70%. Just wanted to pass along my thoughts and observations. They're still running strong, loud and sound "glorious"! I'll let you know if they blow!
jhundt
Netherlands
I should have said that "sometimes some people worry too much about numbers...".
You are not the one who is worrying. Thanks for the information you have shared.
