JCM Mini Clone Issues
Ten Over
Central California
Your pre-amp heaters should be around 3.15Vac to ground. Pin 2 on the power tubes should be around 3.15Vac to ground and pin 7 on the power tubes should be around 9.45Vac to ground.
Ten Over
Central California
I'm also interested in the DC voltage at the junction of R11 (470) and R21 (10k). The grid voltages for V3 (pins 2 and 7) will be nonsense, but I would like to see them, anyways.
imgumby001
America
Your preamp sockets appear to be wired correctly so I'm guessing that you may have gotten the order of the pins wrong when reporting the voltages. I did notice a missing 100k resistor that is normally wired across the v2 socket on the JCM 800 circuit. It normally connects across pins 1,6 and 7 but I'm not seeing it in your pics. Here is our member Rob's JCM 800 layout which shows the resistor across the v2 socket.
I just went over the voltages again, I’m getting what I’m getting. All the sockets are numbered, so I’m definitely not getting them wrong. The numbers are weird, make no mistake. If you consult the supplied voltages for the manufacture they are certainly off what is listed. I just can’t figure out why. All resistors check about where they should be. I just can’t explain why this amp is behaving so badly!!!
imgumby001
America
The junction of r11 & r22 is reading 36.09vdc
V4&5 pin 2 is 3.59vac and 3.6vac
Pin 7 is reading 10.68vac and 10.69
V3 pin 2 is reading 22.34vdc
And 7 is reading 20.8vdc
Hopefully that is what you needed. Thanks again!!
dan40
Richmond Va
Check those voltages on pins 4/5 and 9 again but make sure your meter is set to an AC voltage scale. Just want to make sure you are seeing the correct filament voltages.
Ten Over
Central California
I am looking at a picture of V1 right now. There is a blue wire running from a lug that is clearly marked "1" to a turret that is marked "V1-1" that also connects to R4 (100k) and C4 (.022uF). Do you see the same thing and if so, what is the voltage at that lug?
imgumby001
America
Yes, that’s absolutely correct. The reading is climbing continuously, but it’s around .7vdc currently.
Ten Over
Central California
V1
Pin1 turret v1-1- 226.2vdc
Okay. Now proceeding in a clockwise fashion from that pin on V1 to the next pin, there is a shielded wire coming from the wiper of the Gain control. What is the DC voltage relative to ground on that pin with the power on and the Standby switch in play mode? Clockwise fashion is when viewing the socket from the solder lugs side.
imgumby001
America
V1
Pin2- 0.0vdc
In play mode
