Jazzmaster style Tremolo with Tune-O-Matic Bridge
Discussion in 'Tele Home Depot' started by randyripoff, Dec 9, 2014.
  1. randyripoff
    randyripoff TDPRI Member
    Chicago, IL
    I'm kicking around some ideas in my head for a scratch-built guitar, and I know I want to use a Jazzmaster/Jaguar style tremolo. I'm pretty sure it should work with a standard TOM, but I'm wondering if anyone has insight or experience to share.
  2. Kennedycaster
    Kennedycaster Tele-Afflicted
    Mesa, AZ
    Why would you want to use a TOM? Use an adjustable Mustang bridge or a Mastery. Problem solved. Also, route your neck pocket with about a 3 deg angle to help with proper bridge height & string break.
    Adjustable Mustang bridge.......
    Mastery bridge......
    Bob
  3. Chocklit_Thunda
    Chocklit_Thunda TDPRI Member
    Benoni, South Africa
    A very good suggestion but the Mastery bridge is expensive and not everyone likes it. I personally like the design but a lot of guys take issue with it not feeling the same. The mustang bridge is also a good suggestion and more "vintage correct"
    A TOM will work. A couple of fender models use a TOM like the J Mascis Jazzmaster.
    The problem with the TOM is that it sits on fixed posts while the JM bridge is designed to rock back and forth when you wiggle the Trem bar.
  4. Nick Fanis
    Athens-GREECE
    I have one & it is a FANTASTIC guitar w/o the usual JM bridge quirks & issues
  5. joeford
    joeford Friend of Leo's
    st. louis, illinois
    i'm working on a jazzmaster for a friend right now that has a j mascis body (and a TOM bridge). the TOM and traditional jazzmaster use very similar mounting cups. i've swapped them before on a bigsby tele. not that much work in it. of all those bridge types, i like the mustang-style bridge the best. least rattle and simplest design. they're pre-radiused to 7.25, but i've used them on 9.5" fretboards without an issue
  6. majorbugout
    majorbugout Tele-Meister
    NY
    The rocking bridge has more issues then benifits. I think the best option is to use a roller TOM
  7. rscalzi
    rscalzi Tele-Afflicted
    Macomb MI
  8. chris m.
    Santa Barbara, California
    I have a Classic Player's JM and prefer the TOM. I used to have a Mustang with rocking bridge and didn't like the instability and resulting intonation impacts.
    I agree that a roller TOM would be ideal although a regular TOM seems to work just fine with a little lube on the saddles.
  9. paulo6
    paulo6 Tele-Meister
    london
    I've had a Squier J Mascis JM for over a year and have no problem with the TOM bridge. No idea how it compares with the other bridges mentioned, but I certainly don't feel I'm missing out on anything.
  10. poolshark
    poolshark Tele-Holic
    Tallahassee
    I don't care for standard tune-o-matics with Jag/JM or Bigsby vibratos. They *can* be made to work, but I think it's a poor design - the strings grind over the saddles, the bridge still flexes back and forth, etc. The Mastery is actually very similar, but designed and made to better handle the stresses of vibrato use. While I'm a big proponent of Mustang bridges - mine work great - if you insist on using a tune-o-matic style bridge, I'd go with a Wilkinson like this:
  11. randyripoff
    Chicago, IL
    Lots of excellent information. Please keep it coming if possible. Thank you.
  12. Cat MacKinnon
    Cat MacKinnon Friend of Leo's
    Colorado
    Just keep in mind that if you use a Mustang bridge (including the adjustable one from Warmoth), they've got a wider string spacing and put the E strings really close to the edge of the fretboard on a Jazzmaster. If I were building from scratch (or parts), I'd either get a neck with a slightly flatter radius to match one of the Schaller or Gotoh roller TOM's, or use the Wilkinson-style that Poolshark posted (the saddles can be shimmed to a different radius with a cut-up soda can.)
    Personally I've never had tuning issues with my standard Jazzmaster bridge, although I did wrap the posts in tape to keep the bridge from rocking (I've been meaning to come up with a more "permanent" solution, but the tape has worked fine. Also: I'm lazy.) Putting a small shim in the neck pocket to increase the angle over the bridge is pretty standard for offset guitars too.
