Jazz tone
Discussion in 'Telecaster Discussion Forum' started by craigoslo, Jul 19, 2017.
  1. craigoslo
    craigoslo Tele-Meister
    oslo, Norway
    How does the .005 sound? I'm sure someone around here has something lower than .022.
  2. Robert H.
    Robert H. Friend of Leo's
    N. Cal.
    I use 10's but put an 11 on the high e for a little more umph.
  3. blille
    blille Tele-Afflicted
    Bay Area - California, USA
    It's a bit of an an acquired taste TBH. In the neck can roll it almost to 3 and still retain most of the highs I like to retain so it's perfect. In the bridge it sounds like a cocked wah when rolled off which is not the most versatile. In the tele where I have it , I only have a neck pickup and I use it exclusively for Jazz with 12 flatwounds.
    022 is a great start and if you see you like where it takes you and you use that guitar mostly for Jazz or don't touch the tone knob in the bridge then I would go 005. That's just my opinion, through many mistakes I've learned to be more cautious :)
    craigoslo likes this.
  4. TwangToInfinity
    TwangToInfinity Tele-Afflicted
    Twangville
    tons of mids , front pickup, velvet and leather pick!
  5. sockgtr
    sockgtr Tele-Meister
    Portland, OR
    I'd say the first thing you really want to do is adjust your expectations. A Tele will never sound like an archtop, even if you put a humbucker in the neck position :)
    As for the "thin" sounding E string, if you're rolling down the volume/tone, you're throwing away the frequencies that give body to that string. Also, Fender style pickups are notorious for thin sounding high E strings at lower volumes. The perception tends to disappear with higher volume.
    If you really want to change the tone of the guitar, I'd recommend a different kind of pickup, something like a Fralin Steel Pole or better yet, a p90. Keep in mind if you do go for a p90 or humbucker, you'll probably need to rout out the neck position even if it looks like it already has a humbucker rout. Humbuckers often have "ears" that need a deeper cavity than the body of the pickup and p90's are wider than a humbucker. I've had 2 of my teles routed for these reasons.
    Teles are great for modern jazz tones. For a more "trad" jazz tone, I've given up on Teles and use a Guild Aristocrat or Slim Jim. It's the hollow body p90 combo that does it for me!
    troy2003 likes this.
  6. craigoslo
    oslo, Norway
    Me too.
  7. blille
    I moved from a single coil to a humbucker in mine and I have a casino like guitar (p90, hollow) so I get your comments.
    Then again, one can make it work. It's a matter of taste.
  8. craigoslo
    oslo, Norway
    Ed Bickert is one of my favorites. And this an early video before he added the humbucker.
    Here is my new favorite telcaster player.
  9. RadioFM74
    RadioFM74 Friend of Leo's
    Italy and Switzerland
    Following on the tone control issue. I would try keeping the tone on your guitar fully open, and shaving off just a bit of volume. I used to have the "thin E" problem too, but 11s + this setting do goof things for me. I also second the thick pick advice. I use 2 mm.
    Good luck!
  10. musicalmartin
    musicalmartin Poster Extraordinaire
    Norfolk UK
    I have just done it the easy way .I bought a DV mark Little jazz.Perfect with my Midtown and Telecaster .I use a 4 way switch on my Tele through Van Zandts which beefs up the tone to give a cool warm jazzy tone.
  11. craigoslo
    oslo, Norway
    Conclusion:
    I have been pushing the mids and cutting treble and bass on fender amps with great results but also wanted a solution for my amps with a tone nob.
    I dropped a .015 cap in my tele today and it was exactly what I was hoping for. Great tones and a usable pot all the way down to 0. The thin E string kept all of its volume but isn't bright.
    Very happy.
    Now I can adjust at the amp or the guitar, or a bit of both depending on the backline.
    Thanks for your input.
    sockgtr, blille and fenderchamp like this.
  12. jamester
    jamester Tele-Holic
    Baltimore, MD
    I play my tele for jazz, 11-49 gauge strings.
    The solution for me was a compressor pedal...specifically, one with a clean blend knob. I use the Xotic SP Comp, with only about 25% Low compression blended in. Retains my tone and dynamics, but now all my strings are more even volume-wise, and no plinky issues with the high strings for clean tone soloing.
  13. blille
    Glad it worked out!
  14. dobrojoe
    dobrojoe Tele-Meister
    England
    For jazz tones, you can't beat a 5-way pickup selector with series in-phase and series out of phase. Series in-phase gives a lovely warm jazz tone. Series out of phase is nothing like parallel out of phase, which is thin and weedy. It's a fairly simple mod, and well worth it. I've done this on my three Teles and I don't know why Fender don't offer it.
    El Tele Lobo likes this.
  15. El Tele Lobo
    El Tele Lobo Poster Extraordinaire Silver Supporter
    I'm intrigued. What does it sound like? Can you put up a video demo or sound clip of your in-phase vs. out-of-phase series positions?
  16. musicalmartin
    Norfolk UK
    A four way switch set up makes the neck much more jazzy ,i have one in my Tele.Van Zandt pickups .A good way to get a straight jazz tone on a tele neck pickup is to fit an A2 Alnico pro from SD and a four way switch .Through my little Champ 600 it just gave a pure clean jazz tone with no tone adjustment on light strings .Wish I still had it.
  17. rhcole
    rhcole TDPRI Member
    Petaluma, CA
    I second the compressor suggestion. But, it has to have a blend knob and can't ruin your tone.
    jamester likes this.
