I've scoured and scoured.. Single Coil with Stacked Bucker, grigsby 3 way
Discussion in 'Telecaster Discussion Forum' started by lakeeriemonster, Mar 30, 2020.
  1. lakeeriemonster
    lakeeriemonster TDPRI Member
    Cedar Point, OH
    Position 1. Humbucker both stacks full on... 14.3 (has its own wire attached to both coils)
    Position 2. Split Bucker at 7 (has its own wire on the split coil) with Neck Single Coil at like 6.8 good match
    Position 3. Neck Only for Roy Buchanan! simple 2 wire Bill Lawrence
    I cant find a diagram anywhere.. its a nice PRIMA bucker with 3 wires.. 1 represents both coils.. other is just one. other is ground.
    Id be better off experimenting.. cant find anything and I'm still not 100 percent on how the 3 way works. im rusty.. I've got a bunch of capacitors to try and I want to try treble bleed mod. I have a bunch of tropical fish mullards, some larger ones also, old spragues, some pios. even a couple vit. qs. Im tempted to go with the MOJO Dijon .1 Im a darker cat.. not as clean as Id like yet. Anyone? MATT
  2. AndyPanda
    AndyPanda Tele-Holic
    Bay Area, California
  3. lakeeriemonster
    Cedar Point, OH
    Tough Crowd...
  4. grooveiron
    grooveiron Tele-Holic
    Calgary, AB
    This might work (tone not shown)
  5. Tuxedo Poly
    Tuxedo Poly Tele-Afflicted
    Merseyside UK
    This slightly modified Phostenix diagram may work. HB - red is both coils, black single.
    nathan5782 likes this.
