It followed me home....really!
Discussion in 'Shock Brother's DIY Amps' started by RollingBender, Jul 19, 2020.
  1. RollingBender
    RollingBender Tele-Afflicted Vendor Member
    SW Minnesota
    The solid state relays completely eliminated the switching noise!!!!
    One little glitch remains. When I was wiring up the SS relays on the bench, they were closed. A bit of research revealed that they need a resistance load before they will open. I hooked up the motors and everything worked. The issue seems to be that the low motor, when it gets up to full speed drops resistance below the relay threshold and it cuts out and stops spinning. I will experiment with adding a resistor in parallel with the low motor to see if that will keep it spinning.
    awasson likes this.
  2. RollingBender
    SW Minnesota
    On its way to her debut performance as a rock organ!!!
    awasson, tubegeek and D'tar like this.
  3. RollingBender
    SW Minnesota
    Our finale song was The Who’s “ Won’t Get Fooled Again”. The line out of the organ is running through a few guitar pedals and for that song there is a tremolo pedal set to “chop” at the rate of the song and a phaser set very slow and severe for the other part of the effect. It’s a bit tricky to play the song because the organ sets the tempo and it is bad if you get out of sync with the tremolo. Towards the end of the song there is a 1 minute part with just the organ chopping away. While our keyboard player was wailing away on the solo (it’s really just comping chords and the trem does all the work) a guy came up to me and asked, “Is she really playing that?”
    I even got to play it on a song!!
