Is your telecaster harsh?
Discussion in 'Telecaster Discussion Forum' started by Singles Forever, Feb 15, 2019.
  1. Singles Forever
    Singles Forever TDPRI Member
    Montreal
    I've been a strat guy for a while and I'm new to the Telecaster but loving it. How many people find their Telecaster harsh on the bridge pickup, with overdrive or gain, on the high E string on bends?
    It's just something that happens because the bridge pickup is so damn close to the bridge? Or because it's surrounded by metal?
    I'm partially concerned because I'm afraid it may be because of the callaham bridge I just installed.
    rjp68 likes this.
  2. TheMindful
    TheMindful Tele-Meister
    Sacramento, CA
    Learning how to work with the natural idiosyncrasies of the Telecaster involves its brightness. It can sound great or terrible depending in whose hands the axe is in.
    If I'm not conscious of the treble and I dig in at certain frequencies then sure, it can be harsh. Sometimes I want it to be harsh. Try playing with softer attack in the registers you feel are too harsh for your natural tendencies and see if you can overall balance it with touch.
    rjp68, FrontPU and Singles Forever like this.
  3. DrPepper
    DrPepper Tele-Afflicted
    All volume and tone settings?
    rjp68, bcorig, FrontPU and 1 other person like this.
  4. MrGibbly
    MrGibbly Tele-Afflicted
    SATX
    I don’t find mine to be harsh after several years of getting to know each other. I’ve leaned the bridge pickup away from the treble side just a hair, figured out where the treble knob on my amp needs to be when I have the tone knob wide open, etc. I actually find the typical bridge pickup on a Tele to be a nice sturdy/robust tone compared to the average Strat bridge. I’ve had a couple of Strats, and I’m sure I’ll have more, because they “do a thing” that I like, too. :)
  5. MrGibbly
    SATX
    Great point. I notice I can vary the amount of bite a lot by picking location and angle of attack.
    TheMindful likes this.
  6. Controller
    Controller Friend of Leo's Silver Supporter
    Montana
    Depends on what you need. The bridge will cut through in a mix better than many pickup choices. On it's own it can seem a bit harsh but then use that tone knob.
  7. brogh
    brogh Assistant Admin Staff Member
    italy
    what pickups ? and are they set to correct heights ? there can be here and there some which are very "harsh", i never got a harsh one over all the teles i had ( across many series ).. some where brighter.
    You might just need to get the heights correct
    Chiogtr4x, Nick Fanis and DADGAD like this.
  8. aux8
    aux8 Tele-Meister
    Ireland
    I'm about a year in with a 50s Baja after years with a humbuckered Gibson-esque guitar. I'm still constantly supposed how mellow and rounded the Tele is. Even on bridge pickup... it has a lovely kind of 'tonk, clonk' sound there when clean. I was expecting harsh, but I find it's not.
    Barncaster and Believer like this.
  9. TheMindful
    Sacramento, CA
    Exactly. When I'm playing high E on the higher frets I play closer to the neck to fatten it up a bit and soften up the pick attack which gives it a rounder, fuller sound. If I were to play with a stiffer attack the notes would plink and sound thin. Experiment and find what you need to do physically to get the right tones.
    Barncaster and MrGibbly like this.
  10. memorex
    memorex Friend of Leo's
    Chicago
    Since I use noise canelling pickups, GFS Lil Punchers on one of my Teles, and Fender Vintage Noiseless on the other, they're not at all harsh. Sometimes I wish they had a little more sparkle, like real single coils.
  11. fendrguitplayr
    fendrguitplayr Poster Extraordinaire
    Greater Boston
    I roll the treble off a bit when using the bridge pickup unless it's a scorching song.
  12. Ricky D.
    Ricky D. Doctor of Teleocity
    Raleigh, North Carolina
    A few things you could try...
    Rolling off your guitar tone a bit, like 20% or so, will cut the edge.
    Your amps EQ settings may need more attention.
    Pick the strings farther from the saddles.
    If you are using steel-wound strings, switch to nickel wound to mellow things out.
  13. soulman969
    Englewood, CO
    Not as harsh as my ex. :p
    Pickup type, pickup height, pot value, EQ, all contribute to some degree so you experiment to find what you like.
    I'm also thinking that as a long time Strat player you're just not as accustomed to the tonality of a Tele bridge pickup yet. Give it time.
  14. Keefsdad
    Keefsdad Tele-Holic
    Toronto Canada
    Me too. I think the Tele is a little "harsh"compared to a Strat or a Les Paul, that's why I need one:)
    Dadzmad likes this.
  15. rangercaster
    portland, or
    I roll tone and vol back 20_25 percent to start ... And start there...
    Greggorios likes this.
  16. heffus
    heffus Tele-Holic
    cHICAGO
    The tone knob is all you need. I almost NEVER use my bridge pickup with the tone all the way up. Roll it back for the bridge, turn it back up for the neck. Also use the volume knob to cut highs.
    Greggorios and howardlo like this.
  17. dswo
    dswo Tele-Holic
    East Carolina
    My bridge is brash but not harsh.
    DrPepper and Greggorios like this.
  18. El Tele Lobo
    El Tele Lobo Friend of Leo's Silver Supporter
    That’s what the tone knob is for. If you still can’t get there, try lowering the pickup by half turns til it gets better. If you can’t fix it that way, look for a less bright pickup...possibly something overwound with milder high end.
    Barncaster and FrontPU like this.
  19. LOSTVENTURE
    LOSTVENTURE Tele-Afflicted
    Charlotte, NC
    On all of my Teles, the bridge pickup is dipped on the high side to give me a little better tonal balance. But, even with that slight mode I can still get it to snarl by picking closer to the bridge.
    Barncaster likes this.
  20. pbenn
    pbenn Tele-Afflicted
    Toronto
    Everybody's right on here. Lowering pickups is my vote, bringing back the rhythm p/u height first, raked for no 6th string mud and as stratty as possible on the first string.
    Then in middle mix position, bring just enough bridge p/u height back to make your perfect mix.
    Bridge pickup just ends up a low default position.
