Is this fooliness
Discussion in 'Tele-Technical' started by teleplayer99, Apr 14, 2021.
  1. teleplayer99
    teleplayer99 Tele-Meister
    birmingham, al
    Installed gen 4 noiseless now. Now thinking of 4 way switch. And what is brand I should buy. Got a guy that will do the installation for free. Also is new plate required and what is the best brand, Do not want push/pull. Should I should get obsidian kit.
    Fendereedo likes this.
  2. unixfish
    unixfish Doctor of Teleocity Silver Supporter
    Northeast Ohio, USA
    4 way switch is a great add-on. Not sure of a brand - others here will know.
    El Tele Lobo likes this.
  3. johnnylaw
    johnnylaw Tele-Afflicted
    New England
    I installed one on a ‘52 Reissue. The switch worked fine in the control plate with no modification. I can’t remember which manufacturer built the switch though.
  4. telepraise
    telepraise Tele-Afflicted
    Tampa Bay
    I have 4 ways in both of my teles. I used Oak Grigsby because I'd heard their name a lot. On the first one with a metal control plate I had to file a notch in the blade where it hit the plate on position 4 to get the switch to full seat in that position. On the one in the pictured in my avatar, I just angled the slot in the wood. How are you liking the Gen 4 noiseless?
    Killing Floor likes this.
  5. bender66
    on my bike
    I seem to recall a few threads of members not having luck with noiseless pickups & a 4 way switch.
    Boreas likes this.
  6. Bongoslade
    Bongoslade TDPRI Member
    Delaware
  7. Sparky472
    Sparky472 Tele-Holic
    Austin, TX
    Do it. It’s the single best mod for a Tele, IMHO. Oak Grigsby as others have mentioned. Works with standard control plate.
  8. Killing Floor
    Killing Floor Tele-Afflicted
    Austin, TX
    Oak Grigsby. Pretty sure you can get a pre-wired kit from Mojotone or RS if you don’t like to solder. I’m not sure the brand matters as long as it’s silent and fits. Some cheap switches don’t make the full turn in the slot on the control plate.
  9. Controller
    Controller Friend of Leo's Silver Supporter
    Montana
    Yep, 4-way is highly recommended for normal pickups. Cant speak to noiseless. I haven't had to modify a plate yet, but if you need to it should be easy. Just keep the metal shavings away from your pickups!
  10. Bongoslade
    Delaware
    Try a search for "Grigsby ", that works good luck TP 99
  11. Boreas
    Boreas Friend of Leo's Silver Supporter
    Adirondack Coast, NY
    I found the combination very squawky regardless of pup height. But I blamed the pups and switched to the traditional noisy pups and the tone was perfect. I did not try a 3-way switch first. Don't see how that would matter much except one less squawky position.
  12. bender66
    on my bike
    I briefly did a search and, as I tend to do, found something less important to do.
    I recall it being more of an issue with the build makeup of a noiseless combined with the 4 way. In my search the info I perused had people installing a 4 way w noiseless with some success, so, there goes that.
  13. teleplayr
    teleplayr Tele-Afflicted
    Nicoma Park, Oklahoma
    I used an aftermarket switch plate from Allparts.
