Is there any way to make this go away?
Discussion in 'Finely Finished' started by slick4772, Oct 8, 2021.
  1. slick4772
    slick4772 Tele-Meister
    Pittsburgh
    I bought an Epiphone worn finish Casino because I didn’t want the thick poly finish on the non-worn ones. I had visions of refinishing with nitro. This particular guitar was olive green. I’m quite sure the body is covered with a thin veneer. Worst case I’ll refinish an opaque color - but if I wanted a natural maple look could I -
    1. Keep sanding and hope it goes away without going through the wood?
    2. Fill with a maple tinted grain filler to cover the green
    3. Apply a piece of veneer
    I appreciate any thoughts.
  2. Freeman Keller
    Almost all semi hollows are laminated plates and sides. The usual thickness is about 1/8 inch meaning that the the plies are around 40 thou, sometimes the center is thicker and the veneers are thinner. That doesn't give you much to sand. The other problem of course is that poly finishes are notoriously difficult to remove - chemical strippers don't work. Bottom line is that a refinish is very difficult.
    None of you options is very good - if you keep sanding you will go thru the outer ply. There is no such thing as "maple tinted grain filler" that will cover the green. And trying to veneer the curved surface, deal with the binding and f holes and neck fitment will be a nightmare. My humble opinion, cut your losses and finish it in a nice opaque color that will hide what you have. If you are lucky the grain figure might show thru the finish and look OK. Nitro is a viable options.
    RomanS, mfguitar, ChicknPickn and 6 others like this.
  3. Lowerleftcoast
    california
    +1
    You might be able to use the accentuated grain pattern that is developing by using a wash or translucent finish. Other than that, go with a solid color.
    RomanS, drewg and NoTeleBob like this.
  4. NoTeleBob
    NoTeleBob Friend of Leo's
    Southwestern, USA
    Yep. You won't get the bare wood look without sanding through the veneer or at least dangerously close to it.
    You could have something interesting by sanding it all like the rear, leaving the green in the deep grain. Leave as is and finish clear.
    Or restain a deep color so the dark green color goes close to black and looks like intentional grain.
    Vibroluxer, stnmtthw and Boreas like this.
  5. Boreas
    Boreas Poster Extraordinaire
    Adirondack Coast, NY
    First I would try sanding the dark edges that remain (to match the center) and see if you like the look of the dark grain on the maple. It may just begin to strike you as interesting and unique. I think it looks pretty cool. Then just throw a clear or olive tint finish (perhaps even a burst) over everything and rock that grain.
    RomanS, peteycaster and Mark617 like this.
  6. Sea Devil
    Sea Devil Friend of Leo's
    Brooklyn, NY
    I agree with Boreas. If you try to get the green completely out, the odds are good that you'll ruin it. Just make it even and then do something cool with what you've got.
    The sides are going to drive you crazy!
    howardlo and Boreas like this.
  7. Boreas
    A good burst should help with that!
    Mark617 and TomBrokaw like this.
  8. Mike Simpson
    Gilbert, AZ (PHX)
    Paint it a solid color.
  9. Boreas
    That would be giving in!!
  10. dconeill
    dconeill Tele-Afflicted
    arlington, virginia, usa
    I have three thoughts:
    1. sanding won't work well, for reasons cited previously
    2. paint it a solid color and be done with it
    3. this seems like a disproportionate amount of effort to put into a $500 guitar
    hemmings, howardlo and Mike Simpson like this.
  11. Mike Simpson
    Gilbert, AZ (PHX)
    That would be winning... not screwing around until you mess it up real good trying to make it something it will never be...
    howardlo and stnmtthw like this.
  12. Old Deaf Roadie
    Old Deaf Roadie Friend of Leo's Gold Supporter
    Goonieville, OR
    Step 1 - Paint it
    Step 2 - Sell it
    Step 3 - Get a different guitar
    $0.02
  13. Mike Simpson
    Gilbert, AZ (PHX)
    Or... leave the green in the grain and make it a "feature" maybe with a green or blue tinted clear.
  14. ScribbleSomething
    ScribbleSomething Tele-Holic
    San Antonio
    If I had a vote I suggest to embrace it. Finish sanding the rest of the guitar. Then do a few coats of Mary Kaye white or TV yellow until the grain is subdued enough.
    Then if those don’t work go solid like candy apple red.
    mfguitar and peteycaster like this.
  15. stratisfied
    stratisfied Tele-Afflicted
    Midwest
    No there isn't any way. Don't waste your time trying to sand it. Veneer is too thin to get that level of color penetration out. Just paint over it with a solid color, sell it and buy a guitar in the finish you actually want.
  16. schmee
    High risk, Go solid color. You could try some kind of burst like perimeter with grain showing in the center part maybe...
    Boreas likes this.
  17. slick4772
    Pittsburgh
    Thanks for the replies. I got it for a good price, I wanted to see if that "worn" finish would just sand right out. It is easier to deal with than the traditional gloss poly but I quickly discovered that this green isn't coming out of the grain. I was hoping that there was some miracle that you guys knew about that I didn't.
    I don't like the green because it's too "modern" a finish. I would like it to be more "vintage" looking. I'm going to paint it either black or pelham blue and be done with it. Depending on how it looks, feels, etc, I'll sell it or keep it.
    Boreas likes this.
  18. Mark617
    Mark617 Tele-Meister
    Massachusetts
    I agree with trying to get the edges sanded down to match the inner body. Go slow, take your time
    Perhaps using dyes you could do a burst that highlights the grain . A reddish/ brown tint would hide the flaws and make what’s left pop
  19. Boreas
    Well, you gave it a shot and learned something. That has value as well. Keep us updated.
  20. old wrench
    old wrench Friend of Leo's
    corner of walk and don't walk
    The Gibson semi-hollows, like the ES series, are made from wood built up from 3 plies.
    Back when I was looking into this, they had just changed from using maple and basswood for the plies, to maple and poplar.
    Not sure what Epiphone does, but I'd think it would be a similar construction.
    So - you don't have much thickness to work with before you've gone through the surface lamination and into glue and/or the middle lamination ;)
