Is there an OD pedal that can go from transparent to mid-hump
Discussion in 'The Stomp Box' started by don, Sep 16, 2020.
  1. don
    don Tele-Meister
    The Old North State
    I'm wondering is there is a really versatile OD pedal that would work with all my teles - a Road Worn, A Cabronita and an Esquire with a little '59 humbucker in it? I'm trying to have a 1 pedal board that will work with whichever guitar I decide to play with. My Way Huge Pork Loin is really great with the Road Worn and Cabronita but leaves the Esquire needing some mid hump. I play thru a Princeton Reverb RI. Any suggestions?
  2. Bluego1
    Bluego1 Tele-Afflicted
    Spokane, Washington
    Put an eq pedal after the Loin. Bump the mids/adjust around them to taste. Kick it on for the esquire.
  3. don
    don Tele-Meister
    The Old North State
    I did think about that as a solution - still 1 pedal would be better if possible
  4. MilwMark
    near Arnold's
    That's basically what the Curve control does on your Pork Loin.
    Their Green Rhino also has a low mid and a higher mid knob to tune each of those frequency ranges.
    telemnemonics likes this.
  5. don
    don Tele-Meister
    The Old North State
    I've heard the green rhino is noisy - the pork loin is dead quiet
  6. MilwMark
    near Arnold's
    I don't know. But why not just use the controls on the pedal you have then? That's what the Curve is for. To tune the mid prominence and frequencies to your rig.
    Dan_Pomykalski likes this.
  7. don
    don Tele-Meister
    The Old North State
    I have tried that but there is not that much variance in the mid tone using the curve knob. I have played thru a green rhino and it was awesome but noisy. online it looks like about half the folks complain of the noise for there green rhino so reluctant to buy one
  8. Frodebro
    Seattle
    I have one of these on my board, and it covers just about everything. Four easily accessed presets, or you can use MIDI to bump that up to over 100.
    omahaaudio likes this.
  9. Dan_Pomykalski
    Dan_Pomykalski Tele-Meister
    Madison, WI
    If you’re comfortable with modding, you could try adding a framus mid control to a mid heavy OD.
  10. swervinbob
    swervinbob Tele-Afflicted
    RockinforJesus likes this.
  11. don
    don Tele-Meister
    The Old North State
    I'm probably not a modder and the hybrid pedal looks cool but way to many options for me - I'm just a simple guy :>) Was thinking more along the lines of the new MXR Timmy or something with a mid knob or a mid sweep - might be wishful thinking!
  12. Cali Dude
    Cali Dude Tele-Holic
    California
    I would guess that any TS style pedal could give you better mids. Also a tweed fender styled amp could help with that sound.
  13. naveed211
    naveed211 Tele-Afflicted
    wisconsin
    Mojo Hand Rook. Has a mini toggle switch for an open sounding circuit that can be pretty transparent, and a TS circuit (and a distortion circuit which is also nice).
    Or if you want to easily switch between, you can get the Mojo Hand Odessa which is a Bluesbreaker circuit on one side which can be pretty transparent, and the Rook on the other which you could set to the TS mid hump thing.
    don likes this.
  14. Edgar Allan Presley
    Edgar Allan Presley Friend of Leo's
    Colorado
    Fulltone OCD has the HP/LP switch that clips harder and adds mids at HP.
    hdvades, leonard d rock and don like this.
  15. xtelesquirex
    xtelesquirex Tele-Holic
    International Man Of Mystery
    ZenDrive can
    don likes this.
  16. Bowpickins
    Bowpickins Tele-Meister
    D/FW, TX.
    I also recommemd the Green Rhino. It's my favorite-sounding overdrive, and possibly the best pedal I've ever tried. I've never had any noise issues. Get the MKIV model, which allows you to choose between a "Classic" setting of the Green Rhino, or being able to adjust mids and bass parameters.
    don likes this.
  17. ScottJPatrick
    ScottJPatrick Friend of Leo's
    Stirling, Scotland.
  18. Danjabellza
    Danjabellza Friend of Leo's
    Pahrump, nv
    I always like to recommend the DOD looking glass. Very unique and versatile overdrive. It has a filter(I think that’s what they call it) pre-circuit that effects the low end coming in, then there’s the bass/treble controls which are interactive, but when dialed out essentially remove the EQ from the pedal. It’s a really cool pedal, but pricier than some, even on the used market.
  19. davidge1
    davidge1 Friend of Leo's
    My Bad Monkey does a good job with that. They don't make them anymore, but you can find one on ebay. They had a both bass and treble controls. If you turn them up, it's less middy. Turn them down a little and you get a mid boost like any TS.
    Twang Deluxe and don like this.
  20. charlie chitlin
    Kimberton
    Isn't a TS king of the mid hump?
    Makes a pretty good boost if you turn the Drive down
