there is no need to make any of this complicated, because both understanding the problem (if there is one) and making the proper fix are both easily within the grasp of anyone.
coil wind direction. the out-of-phase chickin pickin tone is cared for by simply reversing the pickup leads (in the control cavity, not on the pickup itself) of one of the two pickups in a tele. the bugaboo comes into play IF that pickup that yer gonna swap leads has one of its coil wires strapped (soldered) to either the bridge pup's base plate or the neck pup's cover. this will be true form 90% of all tele pickups. break that strapped connection by cutting that strap wire - you don't have to unsolder it, just cut it so it no longer is in the circuit. now solder a new wire, to either the base plate or cover, and route it into the control cavity and solder its end to the back of any pot. that's it, done. phasing has now been corrected and the the tone will bloom and be fat.
rod magnetic top polarity. besides have different wind directions, the top polarity of both tele pickups must be different in order to achieve a typical, standard, noiseless mode when both pickups are selected. it doesn't matter which pickup has what polarity, as long as both are different. here's how you do that, it's stupid simple ....
http://www.tdpri.com/threads/flip-a-pickups-top-magnetic-polarity.853731/
