Is there a way to darken a Poly finish?
Discussion in 'Finely Finished' started by Dentron, Mar 30, 2020.
  1. Dentron
    Dentron TDPRI Member
    Fort Worth, TX
    I have a honeyburst G&L that I would love even more if it had a darker finish. Any suggestions?
  2. medownsouth
    medownsouth Tele-Meister
    Tri State, MS
    Nothing that’s not very intrusive, Curious to see if someone has a hack
  3. BorderRadio
    Phoenix, AZ
    I'm just spit ballin...
    But sand it back with some 300 grit and spray on some tinted clear?
    One time I thought about taking my guitar to a tanning booth. Then I realized: "they'll make me explain things" and thought better for it.
    Toadtele and carpenter like this.
  4. Warren Pederson
    Warren Pederson Tele-Afflicted Silver Supporter
    Kelowna B.C., Canada
    brown shoe polish?
  5. aerhed
    aerhed Friend of Leo's
    Boulder, WY
    My natural ASAT has sun darkened. Put it in the sun for a couple decades
  6. EsquireOK
    EsquireOK Friend of Leo's
    U.S.A.
    The only way would be to spray a urethane clear coat lightly tinted with a neutral black. The result would be somewhat like putting lightly neutral gray tinted sunglasses on.
  7. archetype
    archetype Fiend of Leo's
    Williamsville NY
  8. Condor84
    Condor84 TDPRI Member
    Hastings, Fl
    I've used both UV and heat lamps, as well as the good ole Florida sun. The UV and heat lamps work better for turning fresh poly on a lighter maple neck more amber. I usually let them sit basking in a light or two in a closet or even better, an unused bathtub, for a few days. Not sure how it'd work on an already cured darker colored body, however, as I've never tried it. Also, a disclaimer... It goes without saying, that if you use a heat lamp, don't get it too bloody close to anything, and give it plenty of space and ventilation. They get extremely hot, and WILL burn down your house if put directly near flammable objects or enclosed spaces for too long.
  9. tweeet
    tweeet Tele-Holic
    england
    Nitro can...tinted or trans coloured. You can spray nitro over poly...scuff it up first...I'd test it first tho on a spare bit of wood with the poly already on it to see what the results were before spraying the body. A pic of the body would be good.
  10. PapaWheelie
    PapaWheelie Tele-Meister
    Wisconsin
    I've darkened several poly finished necks by spraying them with a lacquer toner them clear coating the with clear lacquer. It gave them a nice vintage look. Behlens and the Reranch have toner in a rattle can.
    Beauty is that if you don't like the look it is easy to remove without messing up the original poly finish and you can try again. The lacquer goes over the poly no problem.
  11. jsnwhite619
    jsnwhite619 Friend of Leo's
    Georgia
    If it's polyurethane, just pull up the rug on a polyurethane finished floor. Our house was only finished last May, and you can already start to see a rug line near a window that only gets morning sun for a couple hours. Maybe leave it on a guitar stand near a window.
    If it's polyester like what Fender uses - or at least used to use - that stuff seems pretty bulletproof to anything.
