Is Power Additive in Series And Parallel?
Discussion in 'Amp Tech Center' started by HD28, May 16, 2021.
  1. HD28
    HD28 Tele-Meister
    Winnipeg MB
    It seems like the interweb answer is yes and no.
    In guitar and amp circuits, regarding resistors, is power (watts) additive in both series and parallel?
    In guitar and amp circuits, does Ohms law E=IR equally apply as does P=I^2R?
    If you use E=IR the answer appears to be no if voltage remains constant.
    If you use P=I^2R, the answer appears to be yes if amperage remains constant.
    The question stems from trying to build a 10% power switch using https://robrobinette.com/AB763_Modifications.htm#10%_Power_In_External_Box
    I wish to use two 3ohm 100W and two 4ohm 100W resistors in series to make a 6ohm and 8ohm 200W 10% power switch, suitable for a 4ohm output 10% power switch for a dual showman, twin reverb, or similar 4 power tube fender amp.
  2. RLee77
    RLee77 Friend of Leo's
    Nevada
    Yes. In both cases, your 3 + 3 = 6 ohm resistor and 4 + 4 = 8 ohm resistor are the equivalent of a single 6 ohm and 8 ohm resistor, with a power rating of 200w each.
    Used as shown in Rob's circuit, they will give you the 10% power attenuation, with a total load resistance of 4 ohms. (8 + 4 = 12 ohms, in parallel with 6 ohms, is 4 ohms.)
    the fatch and HD28 like this.
  3. beanluc
    beanluc Tele-Holic
    California Bay Area
    Power is voltage divided by current.
    Voltage is additive in series, not in parallel.
    Current is additive in parallel, not in series.
    So a power switch logically (to me, I haven't looked at this type of circuit) could be additive in series if it affects voltage, or additive in parallel if it affects current.
    In other words, there's no single answer, and whatever answer makes sense for your application is probably not even related to my over simplification.
    dogmeat and HD28 like this.
  4. Lowerleftcoast
    california
    You would not question this when adding two speakers together.
    Two 25W speakers in series = 50W of power handling.
    Two 25W speakers in parallel = 50W of power handling.
    HD28 likes this.
  5. HD28
    HD28 Tele-Meister
    Winnipeg MB
    Power is additive in both series and parallel.
    Lowerleftcoast likes this.
  6. HD28
    HD28 Tele-Meister
    Winnipeg MB
    Thank you.
  7. RLee77
    Nevada
    Just to show how the power splits up in your attenuator, here's a rough sketch, showing watts for each resistor and speaker with 100w total going in; the total load on the amp is 4 ohms. Since the two 4 ohm R's in series with the speaker won't see as much power, you could scale those back to two 50w R's if you wanted. I'd leave the two 3 ohm R's at 100w each for safe power dissipation.
  8. blowtorch
    Wisco
    power is addictive
    and power corrupts
    absolute power corrupts absolutely
    HD28 likes this.
  9. RLee77
    Nevada
    Bass players are therefore more corrupt than guitar players.
    HD28 and blowtorch like this.
  10. SRHmusic
    SRHmusic Tele-Afflicted Silver Supporter
    North Carolina, USA
    Power = voltage x current = V x I
    Also P = I^2 x R = V^2 / R, from substituting V=IR or I=V/R.
    Power always adds; when looking at a circuit the total power dissipated is the sum of the power dissipated in each element.
    One method: first sort out how much current flows in each branch, then use P=I^2 R to find the power in each resistor.
  11. blowtorch
    Wisco
    and drummers are pure evil
  12. Dacious
    Dacious Poster Extraordinaire
    Godzone
    Singers are the worst - they get thousands of watts in dedicated foh and foldback,and still complain....
    RLee77, blowtorch and HD28 like this.
  13. HD28
    HD28 Tele-Meister
    Winnipeg MB
    Thank you.
  14. beanluc
    beanluc Tele-Holic
    California Bay Area
    yeah, I blew it.
    HD28 likes this.
  15. kbold
    kbold Friend of Leo's
    Well ..... maybe not.
    Bassist requires 10 times more power than the guitarist.
    So, it only takes one tenth of the power to corrupt a guitarist (compared to a bassist).
    Therefore the guitarist is 10 times more corrupt. Allow a guitarist to play through a bass amp ...............
    HD28 likes this.
  16. kbold
    . duplicate
    HD28 likes this.
  17. radiocaster
    europe
    The problem is how you calculate the perceived power rating of the amp and resistors.
    First of all, a 100W amp is rated at that clean, so if you're cranking it you'll get something like 160-200W.
    Second, the ratings of the resistors are understood to be with heavy heat sinks, and a fan might help as well. For example, here's one rated at 100W:
    https://www.tube-town.net/ttstore/high-power-resistor-3r9-4-ohm-100-watt.html
    as you can see, the rating without a heat sink is 40W. So if you just use two of those in the circuit with a Showman without heat sinking, you'll likely fry them and possibly damage your amp.
    HD28 likes this.
  18. the fatch
    the fatch Tele-Meister
    LEEDS UK
    Actually, power is voltage multiplied by current. Voltage is shared between resistances in series, and is the same across both when in parallel. Current is shared by resistances in parallel and is the same in both when in series.
    kbold likes this.
  19. dsutton24
    dsutton24 Doctor of Teleocity Ad Free Member
    Illinois
    In DC circuits, and AC circuits through the audio range, power is pretty well behaved. Once you get into RF, though, things can get weird.
