Is my truck haunted?
RoscoeElegante
TooFarFromCanada
Your Mechanic missed it - short of rewiring it's pretty hard to find that type of open ground.
I hear ya. Over the years, I learned that he approaches American cars...differently. He seems to expect them to be more problematic than Hondas and Toyotas, and resigns himself/me to accepting a pretty low threshold level of diminishing returns. "Well, now if it was a Honda, we could...."
SerpentRuss
North Carolina
Gotta be haunted, either that or just a miracle that a Chrysler product would ever go half that many miles.
The 318 is really a remarkable engine that is almost impossible to destroy. If you pull the valve covers, the top end is a work of art. I've rebuilt two over the year but I haven't had to touch this one. This was the first year with throttle body injection and I've had to put two sets of injectors (there are only two) in it, but not having a carb is a pleasure. I've also put in one water pump, one fuel pump (in the tank *^&!), one radiator, and about 140K miles ago, a transmission. Other than the tranny, I did all the wrenching myself and I work cheap. The tranny was the big decision, because at the time the truck looked only slightly better than it does now and I'd only driven it about 10K when it left me. I talked to the transmission guy and he said it was basically a good transmission and he thought putting $1200 into a truck I got for free was smart money. In his view any truck that runs is pretty much worth $1000. I have to rebuild the rear end very soon. That's a project for this summer.
fenderchamp
omaha
I thought you were going to see the boyfriend in the mirror, or in your dreams. Good story, told well, but if it around the campfire, I think I might be underwhelmed.
dogmeat
Alaska
for the mirror... hot glue. let the glue get really up to temp, use a heat gun to preheat the windshield and mirror.
as for the rams' head... sell it on evilbay. then drive this thing until it quits, strip off the plates and walk
Harry Styron
Branson, Mo
If it were my old truck, I’d try putting one of those very strong neodymium magnets on the outside of the windshield to hold the mounting lug that you glue to the windshield. This will “clamp” it while the glue cures. Then leave the magnet in place.
If this doesn't work (and it probably won’t), drill a hole through the mounting lug, the windshield and the magnet, and join them together with a rivet. Because the rivet will be aluminum and the other metals are steel, you may need to install a cathodic protection system, which would be the first ever installed on a Dodge, which could have saved the company if installed years ago.
However, your truck is not my truck.
