Is my fingerboard gonna wear out
Discussion in 'Acoustic Heaven' started by mally, Jan 12, 2020.
  1. mally
    mally Tele-Holic
    runcorn cheshire uk
    Would you guys be worried about this ?
    Skydog1010 and JL_LI like this.
  2. JL_LI
    JL_LI Friend of Leo's
    Long Island, NY
    Play your guitar. Enjoy it. Life’s full of things to worry about. Guitars shouldn’t be one of them.
  3. mally
    mally Tele-Holic
    runcorn cheshire uk
    Yeah I just took the strings off to Re String it and It looks a bit Funky Probably last me out !
    JL_LI likes this.
  4. 8trackmind
    8trackmind Tele-Holic
    Memphis, TN
    No. Play it. Re-evaluate the situation after the second or third re-fret 30 or so years from now.
    JL_LI, GuitLoop and Dan German like this.
  5. jhundt
    jhundt Doctor of Teleocity
    Netherlands
    what are we looking at that is supposed to be possibly worrisome? All I see is a lovely fingerboard with nice inlays. Are you concerned about the discoloration under the strings? In my opinion, that is part of the beauty of a well-played guitar.
    If you want yours to look new forever, you might try rubbing your fingerboard vigorously with a fine-grade scotchguard pad dipped in a warm-water and dishwashing liquid solution. Dry with a soft towel or paper towel. Apply lemon oil.
    JL_LI likes this.
  6. Tommy Biggs
    Tommy Biggs Friend of Leo's
    Northern NJ
    how long did it take to get to that point? How many hours a day do you play it?
    I wouldn't be too worried. unless you bought it new last week :)
  7. Dan German
    Dan German Poster Extraordinaire Silver Supporter
    Left of the Left Coast
    All I see is normal fret wear. Still a ways from needing serious attention. I wore divots in the rosewood of my Takamine until it was hard to play without sounding like it was scalloped.
  8. Dismalhead
    Sacramento, California
    I just recently restored my old '83 SG. It was my main guitar for about 12 years. Easily has the most hours on it than any other guitar I've owned. After having it sit in a case for a few years I was surprised to see the divots I had worn all up and down the fretboard. It's had two grind and polishes and the frets are practically non-existent. Still plays like a dream. When it stops feeling that way, I'll have it refretted and maybe replace the board. Until that point, I'm just gonna play it.
    If it ain't broke, don't fix it.
    cat dude and JL_LI like this.
  9. fendrguitplayr
    fendrguitplayr Doctor of Teleocity
    Greater Boston
    No worry, just play it.
  10. Allan Allan
    Allan Allan Tele-Meister
    Illinois
    Are you talking about the grime? That'll clean right off
  11. maxvintage
    maxvintage Friend of Leo's
    Arlington, VA
    Yes, your fingerboard will wear out eventually. No doubt about it. Also you will die.
    I would not be worried about that. Just clean it. If you ARE worried about it, you could try, with care, putting a little bit of cryanocrylate glue on the board, to minimize wear
    Texicaster likes this.
  12. Dan German
    This is why I keep coming back to TDPRI—the encouragement and positive reinforcement! :D
    maxvintage likes this.
  13. Skydog1010
    Skydog1010 Tele-Afflicted Platinum Supporter
    North Carolina
    nope I play much worse
  14. Texicaster
    Texicaster Tele-Afflicted
    Arizona
    Yep... eventually ....but not soon!
    I use Dr. Ducks Axe Wax which is recommended by Martin. Harmless and highly effective on RW fretboards!
    it'll probably clean out those divots and make them less pronounced.
  15. Switchy
    Switchy Tele-Holic
    Arizona
    If you manage to wear out your fretboard to the point that it is damaged, then you are a badass man.
  16. zombywoof
    zombywoof Friend of Leo's
    These Days NE Ohio
    I had a 1956 Gibson SJ on which I had worn divots in the board the size of Crater Lake. Relatively easy fix though.
    As for taking care of the board, I use Fret Doctor.
  17. Jimmy Dean
    Jimmy Dean Tele-Afflicted
    Portland, OR, houseboat
    Have never experienced fret or fingerboard wear caused by me. Been playing around 45-50 years & have developed a very lite touch. That being said, everyone's playing styles are different & some players really like to dig in.
  18. Chunkocaster
    In space with Ziggy
    Keep your finger nails cut short and that board won't wear near as much.
    I have worse wear on my rosewood acoustic fret board after 3 years of almost daily playing.
    Mostly due to having really hard finger nails and not cutting them short enough often enough. I let my right hand nails grow a little longer to fingerpick, not gross looking talons but just long enough to use some nail. In doing that the left hand was only cut at the same time so also had nails just above the skin. That's enough to wear a board out fast.
  19. Freeman Keller
    With all that vine inlay it will be tricky to sand the board down when you eventually have it refretted but it can be done. Here is a Taylor that has been played hard and is getting a refret
    I've had marginal luck trying to fill divots with powdered rosewood and CA - if the owner has used any oil products it doesn't work at all (and makes the refret more difficult).
    The wear on that guitar was a little unusual - its all the way up the neck and basically on all frets. You don't see that on acoustics - the owner says that she plays a lot with a capo. She also has moderately long nails.
  20. ClashCityTele
    ClashCityTele Tele-Afflicted
    Washington, UK
    It's called mojo.
