Is it worth it?
Discussion in 'Bad Dog Cafe' started by omlove, Jul 16, 2019.
  1. omlove
    omlove Tele-Meister
    new york
    I have been wanting to buy the set of 8 nut files on Grizzly for a while. It's a good deal and I know this is the necessary tool if I have to work on my nut in the future.
    However, all these wants come from my not so secret desire to achieve my "dream" guitar - not so much about color, or wood, or even neck shape, but perfect setup, perfect geometry alignment and perfect playability.
    I know the nut file set is just the entry into the rabbit hole. Soon or later I need notched straight edge, I need fret file, I need sanding beam, I need various tools to achieve the perfection. Sadly all those are very specific guitar tools, not found in normal home tool boxes. And every each one of them does its sole job and that job only.
    Is it worth it to buy all those tools, just to have maybe one neck "polished" and "adjusted" to perfection so to speak? What is your experience if you have done that before?
  2. Manual Slim
    Manual Slim Tele-Afflicted
    Up around the bend
  3. WetBandit
    WetBandit Friend of Leo's
    Somewhere
    Buy a small piece of aluminum flat stock at home depot or some other hardware store to use as a fret rocker.
    You can then use an aluminum level with sandpaper wrapped around it as a sanding beam.
    And use welding tip cleaning files to slot nuts.
    You can get all of that stuff for really cheap, to try your hand at it before you take the plunge on high end tools that end up collecting dust.
    The notched straight edge is nice but not necessary ime...
  4. ArcticWhite
    ArcticWhite Tele-Meister
    Portland Oregon
    Have you
    Have you tried the torch tip cleaning files successfully?
    My experience using them for blowtorches years ago is that they are very thin and flexible. Nut files are like knives, so they are quite rigid.
    I think tip files will wander, particularly if you try to cut a new nut.
  5. WetBandit
    Somewhere
    Cutting a new nut would likely be an issue, haven't tried that personally.
    But filing an existing nut they work beautifully, I've been using the same set for years.
    You could probably use a regular (small) triangle file to get slots started then finish with the torch files... that would probably work out nicely.
    they also work nicely on brass nuts.
  6. archetype
    archetype Fiend of Leo's Silver Supporter
    Williamsville NY
    If you use any of these once, from then on there's no such thing as once. You'll use any of them again.
