Is it normal for strings to be uneven on a $2000 Tele?
Discussion in 'Telecaster Discussion Forum' started by dscottyg, Sep 17, 2021.
  1. dscottyg
    dscottyg Tele-Meister
    Jacksonville
    I preordered an American Ultra, and the company sent photos of one they have ready to send. The strings look uneven at the heel. You can eyeball the dots on the fretboard and the pole pieces at the bridge pickup to also see it’s off a little. I know it doesn’t affect the sound. I’m just wondering if it’s normal and to be expected on a guitar this expensive, and if it would affect playability? Thanks for your ideas.
    2735E246-01C4-4B40-B267-C506EA8DB9FD.jpeg ED0AF734-A64F-4349-8C72-581D51C16489.jpeg 249A0112-987A-43E1-ACE3-78319680FF7B.jpeg
    shovel80 and That Cal Webway like this.
  2. JL_LI
    JL_LI Poster Extraordinaire
    Long Island, NY
    Loosen the screws securing the neck about 1/2 turn. Pull the neck away from the cutaway side of the body so that the strings are evenly spaced. Tighten the screws one at a time. Check that the neck hasn’t shifted. Readjust if need be. Tighten all screws. Check and adjust intonation. Play and enjoy.
  3. adjason
    adjason Poster Extraordinaire Silver Supporter
    virginia
    that looks well within the range of normalcy to me but it might give me pause or at least ask for some better pics to make sure its not just the angle etc. You could loosen the screws and adjust it I think
  4. Harbinger77
    Harbinger77 Tele-Meister
    Boston
    6 different string guages will never look “perfect” and a photo is likely to distort the spacing further.
  5. Nahtabot
    Nahtabot Tele-Holic
    Well, that's a Sweetwater pic.
    I bet it's more of a camera angle thing than a spacing thing.
  6. Dano-caster
    Dano-caster Tele-Holic
    Snore'n desert
    I wouldn't worry about that to much, if it plays well and intonates well you should be good with it...Personally I don't care for that bridge anyway...
    Tonetele, shovel80 and dscottyg like this.
  7. telemnemonics
    Yes
    Wallaby, irie, LutherBurger and 3 others like this.
  8. Kevin Wolfe
    Kevin Wolfe Tele-Holic
    Lakeland FL
    This^^^
    Not uncommon at all.
    Addnine, Ronzo and JL_LI like this.
  9. dscottyg
    Jacksonville
    Thanks. I just tried it on my 2001 American Tele that is already dead on to see if I could shift it crooked, but it is so perfectly sitting in that pocket, it won't shift. Maybe there would be more play in that Ultra. I should ask if their tech can fix it before shipping out.
    scelestus and JL_LI like this.
  10. dscottyg
    Jacksonville
    Maybe. It's sweetwater. They have directly front shot and an angle shot. The direct front shot is straight because you can't see the binding well. Still I guess it could be a very slight angle.
  11. Lone_Poor_Boy
    Lone_Poor_Boy Tele-Holic
    Colorado
    Haha, keeping it simple!
    Wallaby and telemnemonics like this.
  12. telemnemonics
    I’m turning a new leaf
  13. Lone_Poor_Boy
    Colorado
    Longtime lurker. You always seem pretty to the point.
    Frodebro and telemnemonics like this.
  14. telemnemonics
    Thanks, too wordy though
    Wallaby likes this.
  15. RodeoTex
    RodeoTex Doctor of Teleocity
    Nueces Strip
    It's kind of normal to have a bit more fretboard showing on the bass side so that fatter string doesn't slip over the edge.
    I'd be way more concerned about that Squier-looking bridge.
    jays0n, nojazzhere and sjwieczorkow like this.
  16. jaxjaxon
    jaxjaxon Tele-Meister
    SanluisObispo CA.
    I had the problem on a budget Thinline and the neck and pocket where so tight I had to use a sandpaper on the sides of the pocket to make it wide enough to shift the neck and the screw holes where also tight and I had to make them bigger also.
  17. Mind Flayer
    Mind Flayer Tele-Meister
    Chicagoland
    I think the camera angle on that pic is a little off, which may be creating the illusion that the strings aren’t aligned. Look at the saddle on the left, and then the one on the right. On the one on the left, you can see it’s reflection on the baseplate, but you can’t see any reflection on the one on the right. This suggests that the camera is angled a little bit from the left.
  18. beanluc
    beanluc Tele-Afflicted
    California Bay Area
    Good eye. You can see the same thing under all 6 strings. Heck, it looks to me like the reflection of each string is displaced by pretty much exactly the same amount as the dot between strings 3 and 4.
    dscottyg likes this.
  19. trev333
    Coolum Beach,Australia
    mhea, just give the neck a bump with the flesh of your hand near the nut on the treble side.... job done....:twisted::D
    or a tap on the soft tolex of your amp without taking it off your shoulder....:lol:
    tintag27 likes this.
  20. dscottyg
    Jacksonville
    Sherlock, I think you’re right. Also the screw shows slightly more on the left side. Thanks.
