Is it "bad" if your saddle screws are extremely angled?
Discussion in 'Tele-Technical' started by BenTobith, Oct 22, 2020.
  1. BenTobith
    BenTobith TDPRI Member
    Austin, Texas
    Is this a sign of a problem with the neck angle, or anything else, or just "how it is" for some Teles?
    For example, mine look like this:
    Greggorios likes this.
  2. Billy3
    Billy3 Tele-Meister
    Charleston,Sc
    Wow! Those are some big saddles! Just kidding.I hope they are not that fat. Anyway, what is the deal with your neck, is i straight? what kind of bridge and saddles do you have? what kind of guitar do have? Are any screws asscue ?Have you properly set it up? So many questions to answer!.... If your neck is straight and the bridge and saddles match up to specs, you're probably going to have to shim the neck. Give us some more information so I/we can help. I had an issue like this before. Good pickin'.!
    Greggorios and Weazel like this.
  3. darylcrisp
    darylcrisp Tele-Meister
    big stone gap, va 24219
    that's how it is, based on the adjustments you have on your bridge/saddles. there's a couple threads here talking about the "too long" screws that accompany some fender bridge's.
    you can cut the screws off or buy shorter ones.
    Bensonite saddles has a real nice package set, I think all are stainless, and they offer shorter screws so none are sticking up bothering you-includes worm screws for the saddles as well.
    here's the listing, look at the pics and read the description, tells you all about it. I have these and they rock!
    https://reverb.com/item/34662853-be...9.4RZZagXCi3S2O78x4_Xwv3r8624dqJhcy_UayAj54N4
    Kmaxbrady likes this.
  4. Weazel
    Weazel Tele-Holic
    Location Location
  5. blue metalflake
    blue metalflake Doctor of Teleocity
    ireland
    I’ve never seen anything as extreme as your sketch suggests - looks as though there’s something else “off”.
  6. TX_Slinger
    TX_Slinger Tele-Meister
    The Sticks, TX
    Not an actual thread hijack, along the same lines...
    I'm in the gray area on my recent build where the saddles are pretty high but a thin neck shim could bring in down. Problem is it has an angled neck plate/pocket so a simple rectangular shim in the northern end of the pocket won't work, it would have to be an angled full pocket shim. Also, i don't want to take more material off the floor of the pocket because the body thickness is 1.5" with standard tele neck pocket depth so i'm already pushing my luck there. I could seek out some longer saddle set screws (3 barrel saddle) for more contact area and it prob wouldn't bug me. Pickups i'm using are from another platform and raise plenty high enough. Shim or roll with high saddles? How high is too high with barrel saddles?
    Neck pocket is pretty so i'm also hesitant to add something I'd have to blend in.
  7. jackal
    jackal Friend of Leo's Platinum Supporter
    mojave desert
    Most "full pocket" shims can be trimmed to fit.
    SRHmusic likes this.
  8. TX_Slinger
    The Sticks, TX
    Of course that would be what I would do but it would be noticeable even if trimmed smaller than the body profile.
  9. Billy3
    Billy3 Tele-Meister
    Charleston,Sc
    Hi there! A shim done properly will not hurt the looks of your ax! We are talking about mm 's if even that. Just a little lift in the neck pocket closest to the neck pup?I hope you want your guitar to sound better than it looks. If your guitar needs a
    shim it needs a shim. Can't fuz about it. Keep on
    Pickin'!!
    SRHmusic and Weazel like this.
  10. ArcticWhite
    ArcticWhite Tele-Afflicted
    Portland Oregon
    Let's see an actual picture of the bridge and saddles.
    AAT65 and Billy3 like this.
  11. EsquireBoy
    EsquireBoy Tele-Afflicted
    Paris, France
    The intonation screws of the saddles on my CS were quite angled and they’re often like that IME. It can be a pain to adjust them but if you use a long screwdriver it’s fine.
    Then there are the height adjustment screws. Mine were purposefully angled (thanks to the thread being angled through the saddle), so that they do not rest on the bridge plate screws.
    I use the past because I’ve still got this guitar but decided to put a brass bridge with 6 individual saddles (for other reasons). With this bridge the saddles are not particularly high and certainly not set to an extreme.
    Proof is the architecture of my guitar was perfectly fine, but it’s just the design of the old bridge with its very thin bridge plate that leads you to set the saddles higher up.
    darylcrisp likes this.
  12. Billy3
    Billy3 Tele-Meister
    Charleston,Sc
  13. Billy3
    Billy3 Tele-Meister
    Charleston,Sc
    Hey Weaz! We on the same page or what?
  14. Billy3
    Billy3 Tele-Meister
    Charleston,Sc
    happy!!! Keep On Pickin '
  15. telemnemonics
    964DE0A6-5FB6-4F3F-9637-1D2540B264E0.jpeg This is a correct saddle height with all on spec Fender parts, not much relief, lowish action, and a strong break angle.
    Note that shimming the neck in the usual deep end of the neck pocket will make the saddles even higher, not lower.
    Adding relief will lower the saddles, but we can’t do your setup from here!
    SRHmusic and darylcrisp like this.
  16. Weazel
    Weazel Tele-Holic
    Location Location
    Certainly. The name is Weazel, though ;-)
  17. blue metalflake
    ireland
    +1
    The chances are that if the set up was right you don’t have a problem
    telemnemonics likes this.
  18. jvin248
    jvin248 Poster Extraordinaire
    Lions & Tigers oh Mi !
    You are ok.
  19. blue metalflake
    ireland
    21439405-E22E-4BAE-B843-852F641AC36E.jpeg At the risk of causing confusion, here’s a photo looking across one of mine. Adjustment screws lie pretty flat.
    I’ve always seen this as about normal.
  20. Billy3
    Billy3 Tele-Meister
    Charleston,Sc
