Is a tube amp something for me?
Discussion in 'Amp Central Station' started by Polderpatat, Mar 23, 2020.
  1. Polderpatat
    Polderpatat TDPRI Member
    Belgium
    Where to start.
    I have 2 amps an AMT Stonehead which is a marvelous little amp
    and a Mesa F50.
    The AMT gets icepicky at a certain volume. The Mesa however, seems to have such a big potential in power (for lack of a better description) that every confident hit on the strings blows the volume right up to a point my ears hurt.
    The Mesa sounds bigger than the AMT, yet doesn't takes pedals well, at least on the volumes I play (75-90dB).
    Is it just the Mesa, being to enthusiast at blasting my ears till they bleed? I'm looking for something to live next to the AMT that sounds bigger, wider.
    I play mostly clean with some crunch (use a mayflower for that) and also djent but the AMT does that fine as it is.
    Please help me :)
  2. Shuster
    Shuster Poster Extraordinaire
    Bulverde Tx.
    Grab an Attenuator for the Mesa and crank that puppy!!
  3. roycaster
    roycaster Tele-Holic
    Santa Cruz California
    I sold off all of my Mesas years ago. I got tired of trying to dial them in. Have considered going to the Mesa Boogie web site and downloading the instructions and starting all over from scratch?
    tubelectron likes this.
  4. muchxs
    muchxs Doctor of Teleocity
    New England
    Got an old 12 watter back from the dead this morning. I cranked it up all the way as soon as it was working.
    Having a small amp and using all of it usually works for me.
  5. homesick345
    Beirut, Lebanon
    Some older Mesa models like the F50 are horrible with Pedals. Check a simpler one channel tube amp; usually these do put more emphasis on tone/warmth vs. versatility
    Best is to go & try amps at a music store. Some are nice enough to let you crank; or even bring your own amps to compare side by side.
  6. telemnemonics
    Bigger tube amps have huge transients above what the same wattage SS amps have when you hit them harder.
    Not sure about the Mesa pedals issue but turning down both the amp and the guitar may help.
    Tools can be tricky....
  7. muchxs
    New England
    Less knobs = more tone
  8. getbent
    getbent Telefied Silver Supporter
    San Benito County, California
    magic eight ball sez: try again later.
  9. Ricky D.
    Ricky D. Doctor of Teleocity
    Raleigh, North Carolina
    Sold my Mesa Studio 22 in 2007. Eight knobs plus a 5-band graphic EQ for one channel. Built a 5e3, 2 volume controls and one tone for two channels. Bags of tone at just about any setting. Still my only amp, living happily ever after.
    hdvades and ce24 like this.
  10. teletimetx
    teletimetx Doctor of Teleocity
    Houston, TX
    Just perusing the Mesa propaganda:
    "Don’t be deceived by the minimalist look of this tidy layout …underneath lurks all the tone you’ll ever need. Diehard traditionalists have acclaimed the F-50 clean sound as perhaps our best ever, standing up against their most precious vintage gems. If you play guitar, the elastic bounce and chiming bell-like top bring a liveliness to comping that must be experienced.
    Channel Two is superbly balanced for the medium gain range where purring blues gives way to rock ‘n roll rhythm and soft-clip solo sounds. This mode enables you to zero-in on the region that best fits your playing style and the dynamics of your individual pick attack.
    Footswitching to Contour infuses a double dose of steroids and pumps up the gain to fiery proportions producing one of the most hellacious crunch sounds around. This grinding wall of gain was inspired by our mighty Dual Rectifier® and creates a unique and luscious harmonic spread slightly different, but every bit as menacing as the Recto®.
    Power is served up in three delectable dishes that can satisfy any appetite with their distinctive and different flavors. All these tones are served fresh on a plate of custom Celestions."
    User manual can be downloaded from: https://www.mesaboogie.com/support/out-of-production/f-series.html
    Sounds like a lot knob-turning could be done to find what you like. Plus the specs say it has an effects loop. Some pedals sound ok through an effects loops, some don't, but have you tried?
    It's a 2 by 6L6 power section; classic stuff. Worth experimenting
    [just kidding]: I would trade you two Fender Frontman 25's for your Mesa F50 - Hey they be real easy to use, plus they have built-in reverb!
    Polderpatat likes this.
  11. 3-Chord-Genius
    Winchester, VA
    My experience is that playing loud and clean is harder on the ears than loud and distorted. Overdrive knocks the transients down that would other shatter your teeth and rearrange your DNA.
  12. VintageSG
    Yorkshire
    There are some wonderful single ended amps on the market. From the Champ-a-likes, through amps with a tone control, through amps with a tone stack, gain and master. 6V6 and EL84 output stages get you to around ~5 Watts. Through a 2x10" or 1x12", easily sufficient to exceed 90dB.
    A single EL34, KT66 or 6L6 will get to double figures, power wise. This won't give much of a volume increase, but it does interesting things in its own right.
    A smaller amp, through a large speaker or two, is loud, and very easy on the ears. The natural compression of the output stage removes the peaks that disturb hearing and dental enamel.
    An attenuator would allow you to work the output stage and saturate the output transformer which -may- be what you're looking for. Or just buy something single ended, Class A with gain, tone ( or TMB ) and master.
    Your guitar has a volume control. Set the amp screaming and dial your guitar back. Play with the tone control on the guitar with the amp set neutral.
    More controls = more fiddling about = less satisfaction ( pats Champ-a-like, with its volume control and, err, that's it :) )
    If you have a compressor pedal, play with it. They aren't just for country. If you djent, do you have a noise gate?
    Big amps are such hard work.
  13. Dacious
    Dacious Poster Extraordinaire
    Godzone
    Mesa F50 is a great sounding clean married to a great overdrive/distortion. Really the first amp Mesa got both right on. 85-90db? Too much Amp.
    You need something more like a Champ. A Vox AC10 which has a built in attenuator might be the go.
    hdvades likes this.
  14. Milspec
    Milspec Poster Extraordinaire
    Nebraska
    I don't mean to pile on here, but I guess I am going to anyway. I have never been a mesa fan for the very reason that others have noted...they are difficult to dial in a good tone. Once you find it, they are great, but the task can be a real pain. I do think tube amps are always the best way to go tone-wise, but there are far simplier amps out there where you really have to work hard to find a bad tone.
    I would get rid of the Mesa and find a better option to replace it with...especially if you like cleans.
  15. 3-Chord-Genius
    Winchester, VA
    I don't get that - I had a Mesa/Boogie Studio 22 combo and it was impossible to get a bad sound out of it. It didn't matter how much gain I used, or where the knobs were set, it sounded great.
    Driver3 likes this.
  16. trxx
    trxx Tele-Afflicted
    Between reality and imagination
    I had a dual rec as a kid, and it was impossible not to stop spinning the knobs to try and find a sound that I liked out of it. It was one of the most unsatisfying amps I have ever owned. I tried other Mesa amps over the years to find the same thing. I guess amps are a personal thing.
    graybeard65 and Milspec like this.
  17. trxx
    trxx Tele-Afflicted
    A tube amp is something for everyone. In a perfect world, every amp would have great tube tone at every volume. In the real world, it's a barage of really bad to really excellent, no matter the brand and marketing hype. The good news is that although you will at times end up with amps that you end up not liking because of this or that flaw, someone else will love it and buy it, allowing you to try again.
    Milspec likes this.
  18. fendrguitplayr
    fendrguitplayr Doctor of Teleocity Silver Supporter
    Greater Boston
    Agreed. The natural tube breakup is a beautiful thing.
  19. Stax1
    Stax1 Tele-Meister
    Over here
    Yes. The end. :)
    Sounds like you need a smaller tube amp.. Try a Fender Blues Jr, Princeton/Deluxe Reverb RI, or a Vox AC15 or Orange Tiny Terror; or more generally just a lower wattage tube amp.
    Mesa's are incredibly loud, and sound amazing when they're working hard, but in my experience don't sound that great at low volumes..
  20. stormsedge
    stormsedge Friend of Leo's
    E. Tennessee, USA
    i recommend getting at least two. I have one for when Mrs is home...and one for when she isn't :D.
