loopfinding
Hey all, pondering this question. I haven't seen an SS input on too many tube amps - offhand I can think of some of the egnater stuff, or the modern vox ac10, and then the music man RD 50 (but that's a little bit different than what I'm pondering here). Not talking about the dumble FET where it's an additional stage, but rather just replacing the input triode entirely. I'm having doubts as to whether an input triode is really necessary on any tube amp.
My thinking is basically:
- Most of the distortion in the preamp is going to be coming from the second stage and PI, unless you are slamming the input with a boost, in which case the input stage is contributing to asymmetric clipping. But you could very well just set up a solid state device to not even flinch at an 8-16Vpp signal (like from a boost), pass an even hotter unclipped signal to the second stage, and essentially get the same transfer curve out of that second stage as you would from stage 1 + stage 2.
- Normally with my 2 stage (input + driver/cathodyne) amp I run either a compressor with the output volume jacked or just a 100% clean NE5532 boost in front of the amp to goose it. In a 3 stage design, I'm not really sure when you are driving a clipping stage, the PI, and the power amp hard how much any of that additional asymmetric clipping on stage one really contributes much to the character or feel of the amp.
- The input is the part of the amp most sensitive to noise. Paralleling triodes on the input is one way to get a better s/n ratio. Running DC heaters is a more involved way of getting better filament hum rejection. But a better s/n ratio or hum rejection using a solid state device is much more effective and trivial to implement. It would make for an extremely quiet amp.
- Using a high voltage JFET like an LND150, you wouldn't even need to worry about separate rails for it, and a device like that would pass the signal clean and hot.
- It's considerably cheaper (both short term and long term) than using a tube, allows for a more compact build, and is much less prone to failure.
Idk, what do you guys think, what are your experiences?
