Is a series/parallel with blend possible with 2 pickups?
Discussion in 'Tele-Technical' started by Peter Rabbit, Dec 13, 2017.
  1. Peter Rabbit
    Peter Rabbit Tele-Holic
    Toronto, Ontario, Canada
    I'm looking for a way to use an s/p push/push pot and an m/n blend pot together. Any ideas? A diagram would be nice, but just knowing if it's possible would be good.
    Thanks folks!
  2. Wrong-Note Rod
    Wrong-Note Rod Poster Extraordinaire
    atlanta
    I had my guitar repair guy do it. Its supposed to be the psuedo strat position 2 "quack" sound using wiring mods and a 5 way switch.
    I didnt like it. Yeah, it worked, I mean there was a different sound... but it wasnt a pleasing sound, in my opinion. Instead I had him install the standard 4 way switch thing with the "humbucker" option.
    Theres a wiring mod/diagram online if you look for either. You're talking about doing this with the two "normal" tele pickups?
  3. Peter Rabbit
    Yes, two "regular" Tele pups. I've found diagrams for S/P without blend, and blend without S/P, and some "will this work?" threads with both (on bass forums), but no definitive answers. Also, I'm trying to do this without a switch, using the blend instead.
    Any info is good info. Thanks again.
