Is a neck plate needed?
ppg677
WI
Seems it would be cleaner to countersink holes, use a washer, and attach a neck without a neck plate.
Is it functionally needed?
eallen
Gold Supporter
I do neck ferrules instead of plates from time to time when asked for. You put them in just like string ferrules.
I like 1/2" or 5/8" diameter ones for looks and most you find are quite large. I believe I got my last few at Bitter Root guitars to get the smaller ones. They are a bit of a pain to me when plates in comparison are virtually no work. The look is clean though.
Just be aware they take shorter screws and using the standard ones can bite you.
Eric
Sent from my SM-G892A using Tapatalk
philosofriend
Kalamazoo
If the guitar was to, say, fall down a flight of stairs it would be less likely to split the body wood with a neck plate. Very few guitars will ever be tested to that degree.
Tonetele
South Australia
I'd say yes that plate is useful, not needed.
In terms of physics it distributes the tension on the neck and body minimalisg harm if dropped.
dkmw
Florida USA
Distribution of load is a basic engineering practice. Tying all four screw heads together with a plate also minimizes shear forces on any one screw.
As @Tonetele says, it’s overkill on a guitar, sort of.
But if you’re building a bridge it’s very important.
schmee
NO. I'm surprised Fender stays with the plate all these years. But, it's easy and it works I guess.
jrblue
Santa Barbara
As above, with the caveat that it also depends on the neck pocket and thickness of the body/platform for bolting. This would rarely be an issue except in an unusual design, as in the case of some body carves deliberately intended to remove lots of material from that very location. Though the plate is overkill most of the time, it is inherently a stiffer and better design. Done properly, countersunk bolts work fine; done improperly, they can exercise a splitting force on the body. I have several guitars done both ways, and no problems, but I actually prefer the plate. I'm not building any more, but after reading this thread I think I would countersink a plate!
