Is a Mini Switch ok for an OT/ speaker out switch?
Discussion in 'Amp Tech Center' started by schmee, Feb 18, 2020.
  1. schmee
    I put this mini toggle in because it fit a hole already in the chassis of my Mono 15 conversion to Princeton.
    It's for the multitap ouput transformer.
    I dont know if those mini's are up to the task really.... 125 v ac rated...
    right there in front center:
  2. kbold
    If it fails .....
    Better would be 2 sockets: one less component to fail, and you'll only be switching with cab changes.
  3. moosie
    Western Connecticut
    It's the current that's the issue here, right? Voltage steps way down post OT, and the current conversely rises. That's my understanding, at least, and I wonder if that toggle gets really hot...
  4. Bill Moore
    Bill Moore Tele-Afflicted Silver Supporter
    Silver City, New Mexico
    I had a '94 Twin chassis that had a multi tap OT, Fender used a simple 3 position slide switch, similar to the "bright" switches. I doubt the mini switch will handle any less current!
  5. moosie
    Western Connecticut
    Minimum gauge for speaker wire should be conservatively calculated to handle 3.5A.
    I just looked up a random brand 125V mini toggle, and it's rated for 5A, so you should be fine.
    robrob and Bill Moore like this.
  6. schmee
    Thanks, interestingly Carling does not put amp rating on the minis. The normal bigger amp style are rated at 3 amps.
    These minis are not rated for amps but do say "Insulation Resistance Dielectric Strength 1000 MΩ min. 1500 Volts RMS @ sea level"
    Weird. I'll likely replace it with a full size when I get a chance.
  7. schmee
    Thinking out loud... wouldn't a DPDT, instead of SPST, spread the load across 2 contact sets instead of one?
  8. moosie
    Western Connecticut
    How, it's a single lead, hot lead, right? Series, not parallel. Same load.
    If I'm understanding you...
  9. schmee
    I was thinking with two separate "switches within a switch", but if I wire the switch sides in parallel, so the flow is through both sides of the switch, then each half takes half the load. Right?
    At any rate, I found a similar switch I had that does have an amp rating on it, and it's stamped 5 amp surprisingly... for a mini switch. So it should be fine.
  10. moosie
    Western Connecticut
    Or not surprising. That's what I reported, too, if you recall.
    robrob likes this.
  11. schmee
    Yeah, but the large Carling are rated at 3 amp!
    Hey are you the Moosie that used to haunt the Weber forums a lot?
  12. moosie
    Western Connecticut
    Ah, I see...
    No, wasn't me!
