Interesting theory about Esquires and Les paul Jrs
Discussion in 'Telecaster Discussion Forum' started by Viejo, Aug 12, 2018.
  1. Viejo
    Viejo Tele-Afflicted Silver Supporter
    Central IL
    I read a theory today that the reason so many Esquires and Les Paul Jrs sound great is that they don't have the magnetic pull of a neck pickup interfering with string vibration. What do ya'll think ? it sounds very reasonable to me.
    El Tele Lobo likes this.
  2. chris m.
    Santa Barbara, California
    I’ve heard it too. They do have a unique snap and sustain. I even noticed it when I converted a Tele to an Esquire, but maybe it was a perception thing.
  3. guitartwonk
    guitartwonk Tele-Holic
    People's Republic of Blighty
    Here are my two Gordon Smiths. Can't say I notice any difference in sound between the bridge pickups on these. Given these two beauties are otherwise identical, I reckon the comparison is reasonably scientific. IMG_20161229_195405.jpeg IMG_20160321_122907523.jpeg
    nojazzhere and LocoTex like this.
  4. Nightclub Dwight
    Nightclub Dwight Tele-Afflicted
    Pittsburgh
    Its like Bigfoot. I don't know either way, but I'd like to believe its true.
  5. pictacado
    pictacado Tele-Meister
    Earth
    Couldn't you remove a neck pickup to prove the theory right or wrong?
    SecretSquirrel and Tim S like this.
  6. telemnemonics
    I'd guess it has some effect but when I play a guitar I listen to the sound it makes and adjust my picking and muting so it sounds like I want it to sound.
    If it's too bright I pick for a darker tone etc.
    This is automatic, and I'd have a hard to forcing myself to pick and mute exactly the same before and after adding a neck pickup.
    I choose harder woods that are less resonant so always have plenty of sustain.
    When I played Strats I kept the neck pickup very very low, but they will mess with the strings if up too high.
    All that said, I only play Esquires.
    EspyHop likes this.
  7. brookdalebill
    Austin, Tx
    I have owned a 1955 Esquire and a 1956 Les Paul Junior.
    I kept neither because of a lack of sonic diversity.
    Both had big necks, both had 1 great sound.
    I need at least 3 great sounds.
    There's no room in my circus for a 1 trick pony.
  8. Frank'n'censed
    Frank'n'censed Doctor of Teleocity
    Parts Unknown
    ”Interesting theory about Esquires and Les paul Jrs”
    They’re like the spotlight dance finalists, at a singles pickup bar
    brookdalebill likes this.
  9. gobi_grey
    gobi_grey Tele-Afflicted
    clinton, ia
    I have a MIM Esquire that I've tried different pickups in. I just finished an Esquire build. I was curious to find out if it had the same ring to it as my other Esquire. As soon as I started to play it for the first time I laughed out loud a little. "Yep, that's an Esquire!" They do indeed have a certain sound/feeling to them. They ring more with longer and fuller sustain. This is neither good nor bad though, it's just different. They can be a little "much" at times. If you're just strumming away playing open chords it can be a little too overpowering unless you're going for that particular sound.
  10. Inglese
    Inglese Tele-Meister
    Italy
    I agree.
    Once, setting io my Tele, I first set the bridge pu with the neck pu all the way down, far from the strings then I lifted the neck pu but when I went back to check the bridge pu I found it dull and dead so I lowered the neck pu and thing got better. There I realized the damping effect of neck pu.
    CodeBlue likes this.
  11. CodeBlue
    CodeBlue Tele-Holic
    Southen Indiana
    Agree that there is a difference.
    I used to own a Strat that I had Fender Lace pickups installed in.
    Those had NO magnetic pull, incredible sustain.
    When setting up a new guitar, I always ditch the neck pickup until it's level with pickguard.
    Set the bridge pickup, then raise the neck pickup to taste, try to keep as low as possible.
  12. heffus
    heffus Tele-Holic
    cHICAGO
    I converted one of my teles to an esquire but noticed no real difference. I also missed my neck pickup so I switched it back.
    Still love the look of an Esquire though with the one pickup and the blank pickguard.
    nojazzhere likes this.
  13. jvin248
    jvin248 Doctor of Teleocity
    Lions & Tigers oh Mi !
    I found the secret to Esquires and Juniors after having these varieties:
    -Junior H with coil split to S
    -Esquire H with 4-way for "Neck"/parallel/"Bridge"/series (lowered the pickup then raised the screw poles)
    -Esquire S with Eldred mod on 3-way
    -Strat H with 'volume and out' wiring
    They all improved my overall playing skill so they all sounded better. I started using both the Volume and the Tone knobs where I used to leave them dimed. I'm not a subscriber to the magnetic pull theory, just the natural need to play a little better when limited by pickups. The flip argument is that a Strat or Nashville Tele or a Less Paul should have crazy sustain problems if magnetic pull were a real issue -- but the forces at work are high string tension at 125lbs or so being influenced by a magnet barely able to hold a few paper clips even when stuck right to their faces while the strings are at a distance where the magnetic force falls by the distance squared term.
    Phil X is a fun video and while Bill Kirchen plays a regular SS Tele, his picking and knob turning tricks are always magical to watch and apply to a single pickup guitar.
    Phil X LP Junior
    Bill Kirchen Hot Rod Lincoln
    SnidelyWhiplash and DugT like this.
  14. nojazzhere
    Foat Wuth, Texas
    But then you have to contend with the gravitational pull of the empty neck pickup route....;)
    One trick pony, maybe.....but what an AWESOME trick! (and yeah...I added a neck pickup to my PRS SE One)
    SnidelyWhiplash likes this.
  15. Ricky D.
    Ricky D. Doctor of Teleocity
    Marion, VA
    An excellent example of special guitar player physics. :)
    If you can hear it, good for you. I'll never try to tell anybody what they hear. If there's a difference, it's way too subtle for me to hear. I don't have bat's ears.
    guitartwonk and nojazzhere like this.
  16. EsquireOK
    EsquireOK Poster Extraordinaire
    U.S.A.
    No difference IME, and I believe that properly conducted experiments would show as much. Esquires just have great switching options, and they look better than Teles IMO.
    As for Jrs. – no different than a Special bridge tone IME, and no cool tones via switch. No pickup height adjustments either, like there are on a Special. But Jrs. look way better IMO.
  17. John C
    John C Friend of Leo's
    Kansas City
    For the LP Jrs. I think part of the theory is the neck joint - on the Jrs. you don't have a pickup rout cutting into the mortise/tenon like you do with an LP Specials.
  18. Crobbins
    Crobbins Friend of Leo's Ad Free Member
    Meiners Oaks CA.
    When I come up with LP jr, or an Esquire, I'll give this theory a test.
